I have a pair of Gale 401’s that need the xovers to be refurbished.
Had one tweeter repaired now to the xover dilemma (This could have possibly been the cause of the tweeter failure)
Seeking advice on replacing potentiometers with fixed resistors or a suitable replacement pots. (would need Circuit diag with values etc)
I would appreciate any assistance.
Regards.
Regards.
Just measure from the pot wiper to each end (at your preferred setting) and buy 5W or 10W resistors of those values.
Preferably non-inductive types. You'll need a high quality DVM to accurately measure low ohms.
Many thanks for your reply. I will more than likely have a tech carry that out.👍Just measure from the pot wiper to each end (at your preferred setting) and buy 5W or 10W resistors of those values.
Thanks Dave , I will also hand the info on to my tech cheers 👍for reference
dave
I must chip in here. planet10's schematic is PLAIN WRONG!
The 7uF comes after the 0.3mH.
Otherwise it is a dead short in the midrange.
Not mine. But yes, the inductor will be close to a dhort.
You worl it out Steve, the picture is there.
dave
dave
Please excuse the dumb question, is the pot replaced by more than one resistor, if so how are they wired in?? ThanksJust measure from the pot wiper to each end (at your preferred setting) and buy 5W or 10W resistors of those values.
I'll have a go here.
There are several ways to wire a three terminal potentiometer. The tweeter appears to be wired as a variable resistor 0-5R. You will replace it with a simple, say 3.3R 5W wirewound.
The mid looks like it is more pure 4R potentiometer. Likely you replace the two legs with two 2R 5W resistors, but measurement and adjustment will be best.
The mid pot readings will be affected and taken lower by the other parts of the circuit unless you disconnect it somewhere.
Make some notes of the three readings from the three terminals. Should fall into place.
You might be able to buy replacement pots. Linear rather than logarithmic I'd guess. Maybe 20W.
Many thanks for that explanation. unle I can find a suitable replacement I will definitely be handling this over
I can’t afford to bungle this. Regards 👍Many thanks for that explanation. unle I can find a suitable replacement I will definitely be handing this over to my tech.
- Design & Build
- Parts
- Gale GS401 crossovers
