PARC Audio drivers on sale
PARC Audio full range drivers, from Japan, are on sale, 30-50% OFF.
They are famous and highly valued by wood cone.
DCU-F071W, 5cm Wood cone, 36USD, 2 in stock (new)
https://dream-creation.jp/image/unit/F071W/DCU-F071W.pdf
DCU-F101W2, 8cm Wood cone, 51USD, 4 in stock (new)
https://dream-creation.jp/image/unit/F101W2/DCU-F101W2.pdf
DCU-F101G, 8cm Glass Fiber cone, 45USD, 4 in stock (new)
http://dream-creation.jp/image/3rd_model/DCU-F101G.pdf
DCU-F121W, 10cm Wood cone, 58USD, 2 in stock (new)
http://www.ritlab.jp/shop/product/speaker/pdf/parc_audio/DCU-F121W.pdf
DCU-F121K, 10cm Kevlar cone, 64USD, 2 in stock (new)
http://www.ritlab.jp/shop/product/speaker/pdf/parc_audio/DCU-F121K.pdf
DCU-F131W, 13cm Wood cone, 85USD, 4 in stock (new)
DCU-F131W, 13cm Wood cone, 61USD, 2 in stock (slightly used for demonstration)
https://dream-creation.jp/image/unit/F131W/DCU-F131W-7.pdf
DCU-F131P, 13cm Pulp cone, 71USD, 2 in stock (new)
DCU-F131P, 13cm Pulp cone, 611USD, 2 in stock (slightly used for demonstration)
http://dream-creation.jp/image/2nd model/DCU-F131P.pdf
DCU-171PP, 17cm Polypropylene cone woofer, 100USD, 1 in stock (new)
http://dream-creation.jp/image/3rd_model/DCU-171PP.pdf
The prices may change depends on currency rate.
Shipping cost depsnds on the country too, around 30USD by surface.
Some videos:
https://youtu.be/h0Q4vvlMjR0
Hi
Are you a PARC Audio representative ?
These remind me of the wooden cone from company Airborne
BR
Eric
Hi Eric,
I am a Japanese audiophile.
My friend is a speaker manufacturer who used PARC Audio drivers.
Now he switched to his handmade drivers.
So he is selling his stock at discount price.
Airbourne is nice wooden cone driver,
I suppose audiophiles in overseas would be interested in PARC drivers too.
Followings are discontinued, this is the last chance to buy.
DCU-F131P, 13cm Pulp cone, 61USD, 2 in stock (slightly used for demonstration)
FWIW, those DCU-F121W look like the same speaker sold at Midwest Speaker Repair with a "phase plug" added.https://www.midwestspeakerrepair.co...-audio-mw-7050-8-5-wood-cone-shielded-woofer/
I am not sure how that driver sounds, the details of DCU-F121W:
https://www.parc-audio.com/shop/shopdetail.html?brandcode=000000000007&search=&sort=
Product overview.
Multi-layer wood cone, full-range speaker
The pleasant tone of our uniquely structured wood cone is very attractive.
Despite its compact size, the rubber edges ensure that bass is also reproduced well.
Main features.
1) Multi-layer wood cone
Reproduces the unique lustrous tone of wood cones through the use of our unique multi-layer wood cone structure.
The multi-layer structure ensures both high rigidity and high internal loss, resulting in straightforward characteristics right up to the high frequencies.
The material used is Sapelli mahogany, a hardwood species.
Mahogany is a well-known high-grade wood used for guitars and other musical instruments, but nowadays all species are restricted in trade by the Washington Convention and are difficult to obtain, so Sapelli mahogany is used as a replacement. It takes a long time to dry, but is said to be less prone to deviations after drying.
2) Full-range speakers with rubber edges
Rubber edges, which are rare in full-range speakers, are used. Despite its small diameter, it reproduces rich low frequencies.
3) Aluminium phase plug
A high-grade machined aluminium phase plug is used. It delivers a straightforward mid- and high-frequency range.
4) Low distortion magnetic circuit with short ring
The use of copper short rings reduces current distortion in the magnetic circuit.
5) Aluminium die-cast frame
The high-grade aluminium die-cast frame is used to reduce unwanted frame resonance.
6) Magnetically shielded magnetic circuit
The magnetically shielded magnetic circuit with double magnets + back cover eliminates any influence on TVs and other equipment.
7) Connex damper
The use of a high-grade CONEX damper, which takes airflow into account, reproduces low frequencies with high linearity.
8) Gold-plated terminals
Gold-plated terminals are used to prevent propagation loss with the connecting cable.
9) RoHS compliant
The product complies with the RoHS Directive environmental regulations and does not use hazardous substances such as cadmium or lead.
Translated with www.DeepL.com/Translator (free version)
Following PARC Audio drivers will be out of stock at the end of this month:
