Where is the star that created earth and our solar system?
Yes, the corpse of the Sun will be a sphere of carbon and oxygen, known as a white dwarf.
It will have just over half of the present mass of the Sun.
https://medium.com/amazing-science/the-fate-of-the-sun-dd8c857d22d8
Yes, me learned friend, Evenharmonics is being a bit dim here.
The Sun is going to collapse into a White Dwarf.
How it works. Type G star of one solar mass. The Physics is written in stone.
OP wasn't questioning the whereabouts of our sun. He was wondering where the star/s that gave the materials that our solar system is made of, is.
I was asking a simple question but somehow there are couple of people here makes things sound more complicated than it is necessary. Or is it complicated? idk.
Anyhow, when a star explodes, the gaseous cloud is bounded by gravity to the star so they would move in tandem. They are bounded by the force of gravity.
They cannot move away from each other.
When the gaseous cloud ejected from the star, they move in very high speed away from the star and based on conservation of momentum, they would continue to move away from the star at the initial velocity. Since our solar system is about 5 billion years old, our solar system has move away from the star in that 5 billion years. And depends on the initial velocity, that would determine how far away our solar system from its parent star that gave it its birth.
The mystery is, we don't know the sizes of previous generation stars that kicked the bucket and passed on their "genes" to us.
These are likely to be high-mass stars that form and die quickly.
Low-mass stars use hydrogen fuel so slowly that they can shine for 100 billion to 1 trillion years.
Since the universe is only about 13.7 billion years old, this means no low-mass star has ever died.
Once the star explodes, it no longer has the gravity it once had. I think you are mixing the physics with the rocket launching from a planet.
They do move away from each other because the trajectory of movement is radial so further they are ejected, further each element gets separated from each other.
Is this a new subject now?
Found this info on the web that may give a hint as to how far the solar system is away from its parent star.
Speed of light is about 6.706e+8 per hour.
The gaseous material travels at 4e6 miles per hour away from the star.
In 5 billion years, the solar system would be about = 5 billions years * ( 4e6 / 6.7e8) = about 29 million light years away.
Figure 3: Kepler Supernova Remant. This image shows the expanding remains of a supernova explosion, which was first seen about 400 years ago by sky watchers, including the famous astronomer Johannes Kepler. The bubble-shaped shroud of gas and dust is now 14 light-years wide and is expanding at 2,000 kilometers per second (4 million miles per hour). The remnant emits energy at wavelengths from X-rays (shown in blue and green) to visible light (yellow) and into the infrared (red). The expanding shell is rich in iron, which was produced in the star that exploded. The main image combines the individual single-color images seen at the bottom into one multi-wavelength picture. (credit: modification of work by NASA, ESA, R. Sankrit and W. Blair (Johns Hopkins University))
https://courses.lumenlearning.com/astronomy/chapter/evolution-of-massive-stars-an-explosive-finish/
You lost me at "miles per hour".
Reactions: puppet
I think we've pretty much nailed it, andy2.
We've shown your hypothesis in post #1 to be incorrect.
1. No single exploding star was responsible for the formation of our solar system.
2. Cosmic inflation was not responsible for our solar system moving away from its point of formation.
Happy? 👍
Who said the big bang and conception of our universe/s was the explosion of a large star?
I don't think I hear that one before.
I remember a theory about the big bang, something like a collision of matter and antimatter which caused the big bang and rubber band theory.
No idea if that is a technical enough parlance, or if it is a theory now since abandoned
Studies of the structure of the Kuiper belt and of anomalous materials within it suggest that the Sun formed within a cluster of between 1,000 and 10,000 stars with a diameter of between 6.5 and 19.5 light years and a collective mass of 3,000 M☉. This cluster began to break apart between 135 million and 535 million years after formation.[18][19] Several simulations of our young Sun interacting with close-passing stars over the first 100 million years of its life produce anomalous orbits observed in the outer Solar System, such as detached objects
https://en.wikipedia.org/wiki/Formation_and_evolution_of_the_Solar_System
It will be interesting the mechanism of how the cluster would break apart - probably from collision with each other. This "break apart" is probably the cause of how the solar system was separated from its parent star.
I remember a theory about the big bang, something like a collision of matter and antimatter which caused the big bang...
You remember correctly. Allow me to expand.
The current thinking is that the Big Bang wasn't the beginning of the Universe. There was a period of rapid inflation which preceded it, during which the size of the Universe increased many, many times over.
During this exponential inflation, the energy that is intrinsic in cold, empty space itself was transformed into the hot dense soup of matter, antimatter and radiation that set up the conditions for the Big Bang. The transition from an inflationary spacetime into the beginning of the Big Bang is known as cosmic reheating.
The initial period of extremely rapid inflation set up the entire observable Universe and created the conditions for the Big Bang which produced the Universe we observe today. If you think about it, this explains why the Big Bang occurred everywhere at once, and not at a single point in space.
Ethan Siegel explains this hypothesis is some detail in the link below - I've simply extracted some of the more understandable information - he's cleverer than me - I'm just a 🤓!
https://www.forbes.com/sites/starts...-was-it-like-when-the-universe-was-inflating/
It will be interesting the mechanism of how the (star) cluster would break apart - probably from collision with each other.
As explained earlier, the newly formed stars in a nebula are thrown apart due to internal gravitational interactions.
In fact, stars rarely collide - unlike entire galaxies which often collide - the difference being to do with the relative packing densities of stars and galaxies.
