Where is the star that created earth and our solar system?
Our earth is formed from and out of star dust which comes from a star exploding a long time ago.
If that is that case, then that star whichever it is must be still around in the form of either
a black hole of a white dwarf. But a star big enough to create our solar system, then most
likely it probably ended up being a black hole.
One possible explanation is cosmic inflation. If whichever star it was that exploded a long
time ago, through cosmic inflation, probably be millions of light year away from our solar system.
Our earth is about 4 billion years old. The universe is about 15 billion years old and inflation happens at
very early in the beginning of the universe. Which means that the star that created our solar system
must have explode very nearly early on before inflation and the space between the remnant (that created earth),
expand accordingly therefore it probably be very far away.
But if the star exploded much later on, then it must still be around close by.
I would not think that the "star dust" from which our solar system formed came from just one single dying star.
Our Sun is thought to be a third-generation star and our entire solar system is made of the recycled star stuff of previous star generations.
And cosmic inflation does not occur when objects are gravitationally bound together.
Our earth and neighboring planets were formed by our sun when it was forming, pushing out the star dust surrounding it to move around and start to clump together.
Star exploding, a.k.a "supernova" doesn't leave behind a black hole or a white dwarf. It leaves nothing in its place. Black hole and white dwarf are formed differently which you can find many links on google search.
I can't answer the OP but did read this the other day and thought it was cool:
Both stable and unstable isotopes of beryllium are created in stars, but the radioisotopes do not last long. It is believed that most of the stable beryllium in the universe was originally created in the interstellar medium when cosmic rays induced fission in heavier elements found in interstellar gas and dust.
So to have a Be part a star needs to explode and the material needs to get zapped by cosmic rays.
I have a feeling the James Webb Space Telescope will answer some of this question.
It is, after all, designed to examine the early nature of the Cosmos. Mostly Electrons, Hydrogen and perhaps Protons, being the only early stable things.
Seems to me that Early Stars were extremely huge, short-lived and exploded into much debris and dust, and the remainder collapsing into Black Holes.
Then it all repeats itself a few times.
It is Energy that drives this process on. We should consider Fusion and Fission, which culminates in the Mass Defect of the Periodic Table of Elements.
Also, the Hertzsprung-Russell diagram gave clues to the existence Nuclear Energy as early as 1911-13.
It is probably a waste of time to speculate on the exact evolution of our Sun in the past:
https://en.wikipedia.org/wiki/Sun
And Scientists can only speculate on the Future, which seems to leave us feeling alone in our Local Group or Virgo Cluster of Galaxies, which has coalesced into a lonely Giant Galaxy:
https://en.wikipedia.org/wiki/Timeline_of_the_far_future
But it is interesting that the Sun is 74% Hydrogen, 25%Helium and a mere 1% of other stuff. Not the ratio in the Planets at all. We tend to Iron 56.
I read that the Sun and Earth share the same refractory elemental abundances, and that, to first order, the Earth is a devolatilised piece of the Sun left over from the Sun’s formation.
The ∼ 1.5% of the mass of the Sun that is not H and not He, consists of oxygen (43.0%), carbon (17.3%), iron (9.7%), neon (8.2%), silicon (5.7%),
magnesium (5.1%), nitrogen (5%), sulphur (2.9%).
Yes. The reason the Sun has an abundance of H and He is because once accretion runs away with itself, the core becomes very massive, gravity very strong and it is then able to accrete light elements. Small planets with weak gravity struggle to hold onto light elements like H and He. So, the earth’s makeup and the suns are actually linked very closely since we both formed from the same cloud of gas from a previous super nova. You also see this with a planet like Jupiter - the core at the centre is about 15x the mass of the earth, and this enabled it to draw in lighter elements from the surrounding cloud of matter.
BTW, the density at the centre of the Sun is about 150g/cm^3 or 12x that of lead.
