Wanted- 2 Black Gate VK 47uF 160V
I bought 10pcs from mpercy a few years ago maybe in 2018 when suddently it was available when i was just having fun for checking his pdf catalog 🙂 I paid as price list if i remember correctly around $4 or $5 each
just checked now he already removed BG caps from his catalog
Check out Mouser or Digikey for a ~47uF film capacitors (or a single 95uF) if you have enough space for them - a film cap will have much higher performance than any electrolytic cap. If you need to mount them a little ways away, then just use tightly twisted leads that will almost eliminate the lead inductance.
Thanks for the recommendations but this is for a output board for a DAC board.
I only want what I asked for... Thanks again.
Person asks for 2 x coffeemaker Braun KF47 in the color white. A member advises on using a Jura coffeemaker in chrome, another one advises on using Saeco. Another member mentions to have found the KF47 in white 4 years ago almost for free but they are unobtainable in 2022. Then a seller responds he has 2 x coffeemaker Braun KF47 in the color white NOS/NIB (anglosaxon explanation to the thick: exact match) and another member even points to a thread where that is described. "Searching" (not really) person asks "what do you have?". Well I have 2 x Lamborghini tractor, maybe a leftover Boeing 747 too and I can also bake you a good burger?!?!? Seller says "forget it" and then "searching" person asks "forget what?". Well that would be to fill up the car 😀 Other member intervenes and corrects seller ("he only has KF47 in black") probably thinking seller is phantasising or who knows what?!
Maybe that kind of demented communication is normal in some circles (smells like high voltage area) but not in mine so I said "forget it" indicating I won't sell. All the best!
Reactions: Reima
They're probably fake.
