Good, if you mean (outputs). What is generating the input signal? You're running into an 8 ohm load?Absolutely. For the overall output test, I am connecting the negative scope lead to the ground bus bar (red inputs) and the scope probe to the black speaker terminal, for each channel.
Yes outputs. I’m using a Analog Discovery 2 to generate the signal and two 8ohm non-inductive loads.Good, if you mean (outputs). What is generating the input signal? You're running into an 8 ohm load?
Your test setup looks good. Any progress with the Amp?Yes outputs. I’m using a Analog Discovery 2 to generate the signal and two 8ohm non-inductive loads.
I FIGURED OUT THE PROBLEM!
I also feel like a complete idiot. The left side of my dummy load/speaker rig had a problem with it. Once I switched the amps output to the right/good dummy load all was well. Outputs are identical. Ugh!
Thank you all for the help! Sorry to waste your time.
