Sony preamp capacitor choices
So, going to recap this sony pre, it's a ta-86 but wanted to run through the circuit diagram to spend my money in the right places, so in the pic below have I circled all the signal caps? Thanks
They are in the signal path of the Bass Boost circuit. You bypass it when you connect to Output 1. If you only use Output 1 then don't worry about it.
Should be no issue replacing them with film, some might argue it will slightly (maybe not at all) change the original sound.
Note that C306, C307, C310, and C311 circuit can be replaced with a single 10uF non-polarized cap.
So this is because two in series would make them 5uf but because there in parallel the one 10uf to replace all 4 is good?
Hi, C306, C307, C310, and C311 could be just 1 good quality physically fitting 10 µF MKP or MKT cap. I would then omit C308 as paralleling caps is not my cup of tea.
C402,C403 and C404, C407 can all be MKT film caps. C408 and C409 can be good quality electrolytic caps. As usual I recommend Wima MKS2 in 5 mm if these fit. Choose highest voltage rating available in that size. Except C408/C409 all the cap should be bipolar in theory but that was then not a possibility. Now it is.
When going film caps then this is the final recap.
Thanks for this, so C408/409 bypass cap? A good quality cap such as Panasonic FC/Fm
With modern caps like FC no parallel cap is necessary but this is probably open for debate. As much as it was once in fashion... electrolytic caps have become better and in many cases just 1 good cap is enough.
Now I forgot most of those old Sony devices but if the regulators tolerate it you can also use MKT 4.7 µF for C408/C409. If you will be using Wima MKS2 then pretin the lead wires before soldering them into the board.
Yes but a bipolar type capacitor like the little green nichicon muse ones .If you'd have read the topics in the links i posted previously instead in engaging and making a new topic on the same subject you'd have known that already...
Seems somewhat harsh considering one thread relates to the matching power amp to this and the other is on a similar not the same pre amp, in any case both threads don't give any answer the the asked question!
Ok.I'm sorry then.For the future, any cap value found in a decent commercial product can go down by 100% and still give a good result because electrolitics are usually expected to dry out so the initial value is always higher than needed.
Usual modders are going to increase a lot of the cspacitor's value thinking that bigger is better which is not always the case.
I think you mean 50%. Besides electrolytic are normally +/- 20% and that is steady state ( voltage and temp)
But before changing value, better see what the function is. PS bypass you are playing horseshoes, The DC blocking cap on the feedback HP filter, maybe more important. Anything in the signal path can be a pole or zero and effect stability ( but those are usually very small and close tolerance caps)
