perry babin i need your help! hifonics brutus bxx4000.1d blown capacitors, replaced, still in protect. guessing driver board ?
There are at least two types of input circuits on this general type of amp.
The most common has the RCA shield connected to the secondary ground (and negative speaker terminal). This type often has a 1k resistor for R-gnd and a 0.1uF capacitor for C-gnd.
Another type has a noise cancelling input and no direct connection between the RCA shields and the secondary ground. I've seen this type with a 1k resistor or a jumper wire for R-gnd. The C-gnd component can be omitted or a 0.1uF capacitor (which is useless with the parallel jumper wire).
I think it would be safe to use a 1k resistor for R-gnd but I can't be 100% sure because the RCA shields reading so low of a resistance doesn't really look like the noise cancelling input.
If you can get the value or diagram, that would be great but manufacturers, with few exceptions, are not very helpful.
Remove them from their pads and see if you get any readings across them.
took off c gnd and r gnd, tried to get any readings with a multimeter and on any setting nothing comes up at all.
i then proceeded to put the 2 chips under a 15x microscope and well... the numbers are completely fried and burned i cant tell anything except a shiny metallic surface ontop.
are other tricks in the book we can try to decipher these chip ratings?
I don't know of any other way.
I'd install 1k worth of resistance, assemble the amp and test with a 20 amp fuse in the B+ line to see if any problems show up in the vehicle with the engine running (to check for noise)
would this spec be appropriate to replace the C and R gnd
  • 1k ohm - 1/8 Watt 0805 SMD Resistor Resistors 5% Tolerance (Ships from US)
  • Resistance: 1k ohm
last question, what voltage would i need?
i would assume to just get the highest voltage rating i can find? 50v or something as long as the .1uf matches up and i go overkill on the voltage spec i should be good yes?
