Hello,
I hope I am in the right place.
I have some mic preamps with no power supply. The stock PSU is a linear supply +/-15V @ 1.2A and +48V @ 200mA (phantom power).
I would like to build a linear supply that can meet these specs. Off the shelf options like this guy seem too expensive. And I don't like the idea of shoving something on it's own chassis into my chassis.
Is there a generic power supply available that would supply the necessary quiet power? Possibly just as a PCB?
I have an electronics shop, mostly do repair. Should be easy to put something together but hoping for a somewhat off the shelf solution, not looking to design my own board. Hoping a generic PCB supply exists and I can just grab a chassis and toroidal PT and put it all together.
I did see the DIY Audio Universal Power Supply but the board is out of stock and not sure if it's the best option.
I figure I will probably have to use a separate board for phantom power.
Thanks in advance for any input.
Thanks for the reply Rayma.
To shorten my question and be more clear: I am likely looking for a dual rail plus phantom power pcb that I can DIY that is capable or providing the power requirements in my title.
You can use a linear regulator IC for the 48V with a raw DC supply. But it will be a significant project to design and build.
https://www.ti.com/lit/ds/symlink/tl783.pdf?ts=1644266189209&ref_url=https%3A%2F%2Fwww.google.com%2F
But I would get this instead.
https://www.sweetwater.com/store/de...mCdqnpfxuCPzKu3akOBoCrgAQAvD_BwE&gclsrc=aw.ds
For the 15V supply you'll need a separate circuit and transformer. There are lots of pcbs and built-up boards for that.
The one you posted is a general purpose high power supply. You'll only need 100mA or less.
AN example: https://www.ebay.com/itm/273342376561?chn=ps&mkevt=1&mkcid=28
Why do you think I'll only need 100mA or less?
Sixty bucks for a MONO supply, even if a Good Brand, seems steep to me?But I would get this instead.
The requested 200mA would support 16 or 20 Phantom mikes.
I don't see any clue if this is two 4mA chips or a 48 input all-frills console. "I need a truck, tell me what to get?" Well, for hauling beer or bullets or boulders? 6-packs or kegs?
You didn't say this was for 20 mics simultaneously, that's rather unusual.
Then you'll need a custom designed 48V circuit, and a fairly healthy op amp supply.
Won't be real small, due to the transformers and heat sinks. The LV supply you posted,
uses the large chassis for a heat sink.
- Power Supplies
- Mic Pre Power Supply +/-15V 1.2A +48V 200mA
