The Last Resolute RA2500/0105 Tripath TDA2500/0105 replacement boards
I managed to make a deal with Profusion and purchase the last FIVE Tripath TDA-2500/0105 replacement boards they had!
The version I got was the 0105 version which i believe is the higher voltage version. they are the same board as the 2500 board with a couple resistor changes. But which resistors are different I am not sure. My contact at Profusion no longer had the info.
these boards were drop in replacements for the Tripath modules. I have used them in the past to repair some Audio Research 300.2 amplifiers that used them and they operate even better then the older modules.
I would really like to track down which resistors are different If anyone has a 2500 board and could take some photo's, please PM me. I would like to offer these up for sale and be able to modify them to the 2500 version if someone needed that specific version.
anyone have any info??
I have a Zapco c2k 9.0 I’m not sure exactly what you need a pic of I know you are probably not using that amp but do you want to sell some of your 0105a or do you know anyone that is a real chip? I want all new chips is why I m asking.
I am interested in buying these I gotta double check something with a guy who is gonna mod and upgrade my amps I want new chips in also.
i am using a mix between 5 zapco 9.0 amps using (3) ta0104a (1) ta0105a (1) tda2500.
The tda2500 and 0105a are the 2ohm versions of this amp and I am needing all 4 ohms all the 0104a is 4ohms I read about cbsbgine resistors as well to make them 4ohms work fro full power instead of two ohms. If you happen to know what I am talking about lmk how much are you selling these for?
definitely interested for sure though
