amplifier differential outputs
would it work like this?
What is this, an active series crossover? This could present a serious problem for the tweeter when the WOOFER amp clips. Superposition fails when linearity does, and you may put more power than you realize into the poor tweeter, and at lower frequency. Much more than with “normal“ clipping where there is an HPF involved to keep unintended signal out of the tweeter.
maybe with the addition of two diodes it works
