I'm planning out a build of Pete Millet's NuHybrid HA. I've ordered the PCB and truly appreciate the comprehensive build instructions.
The BOM from Mouser has a few components that are out of stock that I dont trust myself to find replacements:
Cheers
- Mean Well Wall Mount AC Adapters 25W 24V 1.04A Level VI USA plug (GST25U24-P1J)
- TI Linear Voltage Regulators 3.3 V 500mA Fix Pos Voltage Regulator (UA78M33CKCS)
TE Connectivity Low Signal Relays - PCB 24VDC Non-latching Single coil P2 (V23079A1005B301)In stock in 01/24- Kemmet Common Mode Chokes / Filters 0.5amp 3.4mH (SU9V-R05034)
- onsemi MOSFET FET 60V 5.0 OHM TO92 (2N7000)
- STMicroelectronics ESD Suppressors / TVS Diodes SM6T Transil series (P6KE33A)
- Kobiconn RCA Phono Connectors PHONO DUAL RED/WHITE (161-4218-E)
Cheers
For the wall AC adapter, this looks similar (identical besides price and "region" spec, that I can see). The spec sheet says its for medical vs. industrial.:
Mean Well Wall Mount AC Adapters 25W 24V 1.04A Medical USA plug
Mfr. Part #
GSM25U24-P1J
Mouser Part #
709-GSM25U24-P1
Mfr. Part #
GSM25U24-P1J
Mouser Part #
709-GSM25U24-P1
I dont see a quick replacement for TI Linear Voltage Regulators 3.3 V 500mA Fix Pos Voltage Regulator (UA78M33CKCS); putting that aside a bit.
onsemi MOSFET FET 60V 5.0 OHM TO92 (2N7000)'s alternate on the XLS BOM is in stock -- https://www.mouser.com/ProductDetail/Microchip-Technology/2N7000-G?qs=yU2N9dt%2BrfnyR/OhNomgZw==
Phono connectors have an in-stock alternate on the XLS BOM -- https://www.mouser.com/ProductDetail/CUI-Devices/RCJ-2123?qs=WyjlAZoYn50RZapIrjfyUQ== as well as several "optionals" in the doc.
The Digikey alternate part # for STMicroelectronics ESD Suppressors / TVS Diodes SM6T Transil series (P6KE33A) lists a direct substitute at https://www.digikey.com/en/products/detail/littelfuse-inc/P6KE33A/285943, also listed at https://www.mouser.com/ProductDetail/Littelfuse/P6KE33A?qs=sGAEpiMZZMu2MsBvHNoAnJMUr%2BBs2TVC on Mouser.
I may need assistance verifying if this is identical.
Medical grade are better as the leakage currents have to be very low, ie less problems with humFor the wall AC adapter, this looks similar (identical besides price and "region" spec, that I can see). The spec sheet says its for medical vs. industrial.:
Mfr. Part #
GSM25U24-P1J
Mouser Part #
709-GSM25U24-P1
Using a 7805 would simply mean that the bias could be adjusted from -5 to 0 instead of -3.3 to 0. LM78033 are also hard to find because linear regulators are a poor choice for low voltages, unless you are talking about a voltage reference like TL431, which might be a better choice.
At first I noticed that the regulator needed to sink the tube cathode currents when such regulators have no sink capability, but when I did the math, I realized that the tube current is only about 2x 10/475k, ie 42uA which will only drop 0.02Volts across the bias pots, so the regulator is just powering the pots up to 3.3VDC (6.6mA).
I assume you understand that this project is deliberately low fidelity. There are a lot of these audio devices with a tube stuck in the middle in order to generate the tube sound, i.e., distortion. I would use a TL431 or a 3.3V Zener instead of the 78M33, but then, I have no sympathy for the whole project.
I appreciate the feedback. As for being low fidelity -- no need to worry, I am in this for the DIY fun of the hobby.Using a 7805 would simply mean that the bias could be adjusted from -5 to 0 instead of -3.3 to 0. LM78033 are also hard to find because linear regulators are a poor choice for low voltages, unless you are talking about a voltage reference like TL431, which might be a better choice.
BTW, if you use a SWPS, be sure the AC input is grounded to earth ground. Otherwise, the input filter puts half the AC line voltage on the DC output, a huge source of hum noise.
It occurred to me that I would not use a 3.3V supply and pots. I would use DC servos from the outputs back to the tube cathodes, ie DC feedback that centers the tube current automatically.
- Headphone Systems
- Looking for Replacements For Unavailable Parts in Millet Nuhybrid BOM
