Old Soul
Bubba Bob will tell more, if in mood
Here is the link to Crocker Nuclear Laboratory on the campus of UC Davis
http://crocker.ucdavis.eduThere is a history section. I directed the facility from about 1991 to 2008. It was also the base for my particulate air quality research. Crocker is known for its Proton Eye Therapy and Semiconductor testing facilities as well as particulate air quality research and medical radioisotope development.
I think Nelson or Kent English posted some pictures of Nelson's visit but I can't seem to find them. Sorry
Aah! I‘m fabberglasted!
Me here, I‘ back in business. No testbed, but really nice values 😊
But the germanium bug gets really warm—like hot to the finger warm (second-last to last stage on papa‘s scale…), worries me a bit.
if you want it working now, decrease Iq to, say, 600mA and chill
in a meantime, prepare L bracket in length of at least 100mm and replace existing one; you can keep position of Ge as is, longer length of bracket will increase thermal transfer
lapping/sanding bask of bracket is helpful, in case of uneven extrusion - not all brackets are made in same quality
edit: in critical cases, everything is important; for Ge, having relatively small contact area ( at least for ZM Chicken, thinking per datasheet), even thickness of Mica and thermal goop used is important
tiniest possible Mica and best goop you can find; I have some generic ones ( without data) and I'm using that only for heatsink slapped on TO220 or such, nothing more critical
you got both channels to behave, or still at first one?
Thank you, mighty ZM
I'm still at the first one (was, actually, will continue mañana).
Already guessed it would end with another bracket. Oh naïve moi ...
I lapped and sanded the bracket almost like a katana-swordsmith. I doubt the alloy isn't the best (it's rather standard stuff, but I didn't find the better conducting alloy.)
The Ge has a pad of red keratherm (cutted by me), the bracket is connected with the best goop I could find (
WLPK10 - Wärmeleitpaste 10ml 10W/mK, Fischer Elektronik) — I always get a buzzing head when I try to figure out wether a high W/mk is better or not...
Where did you guys get these Ge’s? Chernobyl?
ZMighty is having some, still ........... but you are not old enough to play, and be content, with Old Ge :clown:
sort of Al is not critical for thermal transfer, as it can be for machining; so - you're good
everything else you listed is OK ........ so just replace L bracket with longer one
To be successful in part hunting, it needs to be a habit, not an activity - meaning you are always doing it. If you can stop doing it then you are healthy, but if you can't control yourself but you are happy then happy sick is just as good 🙂
I got mine on global auction site and there are a few different candidates mentioned in the thread. If I list it here, it will make it too easy for parts scalpers to grab them but last week there were still some candidates still available.
