ACA Mini "Almost Clone" Board - Outside U.S.A.
Joined 2007
THIS GROUP BUY IS OFFICIALLY CLOSED
Since I'm a glutton for punishment, and I don't want to leave anyone out:
This is an ACA Mini PCB with artwork designed by Mark Johnson following the Nelson Pass circuit. It is very close to the artwork released by Nelson Pass for the boards which were given to some lucky participants of the Burning Amp Festival. Mark was gracious enough to produce a number of his boards and give them away: I was one of those recipients. I have built the amp using this "Almost Clone" board and it works and sounds fantastic. It was suggested that a group buy for this "Almost Clone" board get started...so here we are.
This group buy will run with the quantity limited to 20, and the time limited to two weeks, whichever comes first. This thread is for those OUTSIDE OF THE CONTINENTAL U.S. ONLY. If you live within the CONTINENTAL US please post HERE.
Photo's of a completed amp can be viewed in the ACA Mini thread #462
Of course you will be using the Nelson Pass article for a description of the circuit, build guide, and biasing instructions found at the beginning of the ACA Mini thread #1
Cost of the board will be $12 with you paying the actual shipping cost from my address in Hudsonville, Michigan 49426 USA. Please check the actual shipping cost before adding your name to the list.
To purchase a board simply copy the post with the current list of names, add your name and quantity, update the total, and paste to new post.
This Group Buy will end on January 22, 2022 at 12:00pm EST
Thanks for looking,
Kevin
micio_mao 1 board - Italy
gary s 1 board - Australia
Deke609 1 board - Canada
spind 2 boards - Canada
diykong 1 board - Hong Kong
kchau22 1 board - Hong Kong
jens r. 1 board - Germany
Franz Gysi 1 board - Switzerland
Total 9 boards
jostwid 2 boards - Switzerland
Total 11 boards
Jostwid 2 boards - Switzerland
Chuck 2 board - Singapore
Total 13 boards
Kokanee 2 boards = Canada
Total 15 boards
To ease Kevins life, correction from #12
Angchuck 2 board - Singapore
Total 15 boards
strongbow60 1 board - Sweden
Total 16 boards
Andrewbee 1 board - Cayman Islands
Total 17 boards
I feel like I've been neglecting the "outside the US" group. Now that the US group seems under control, I'll be concentrating more on this group. Tomorrow I'll set up your spreadsheet and start opening conversations with the individuals on this list. Don't worry, all boards for both groups will be ordered tomorrow.
