just an idea, an analog eq unit that does CD de emphasis on early CDs. beyond my abilities, unfortunately
9db from 1khz
time constant of 25uS
This is why they stopped doing preemphasis. Nobody got it right.
Two time-constants 50μS and 15μS. Ends up near -10.46dB
http://pspatialaudio.com/cd_deemp.htm
A lazy web-search turns up https://offset.skew.org/wiki/User:Mjb/Time-constant-based_EQ which leads to https://www.radonmaster.de/robernd/tAFILTER.html which seems to be an exact implementation. However the loss is non-zero and the impedance is high, so I re-scaled it.
Original, loss taken out, and Z scaled down.
Note that most CD players have some series resistance on the output, and for many popular-price boxes it may be 470Ω. IF so, you will be super close putting 76nFd and 200Ω across the output.
My understanding is that most cd players made in the last 20 years are "faulty" in that respect, because they stopped making 14 bit cds 30 years ago.
You could try fishbone's truth and soul, or the dorchester variant of black sabbath's paranoid. They're not 14 bit that I know of, but they do have pre emphasis.
Why not look at some old service manuals to see how it was implemented. You could model (simulate) the circuit and then design your own to match if you wish. The inductors you mention may well be part of the early 'brickwall' filters that early players used to provide a steep cut beyond 20kHz.
This is from a CDP101 which should have it absolutely correct.
