small (?) voltage variation on SET amp PS: is this normal?
Hello,
I have measured the HT on a 300B amplifier power supply and there's a small voltage variation occurring. The voltage reads in average 542.0V on the multimeter, but it drifts +/- 1V over a minute. I made a small 1 min video of the measurement, would really appreciate some feedback. The PS has LC filtering and uses two 5R4WGY tubes for full rectification. Is this normal? if not, what can be causing it? Rectifier tubes?
Can't see any cap leaking... there are a lot of them, it would be a nightmare to test them all.
The measurement was done without any signal (inputs shorted)
Thanks in advance
Multiply the change in Line voltage by the ratio of your (HT/Line)*.707 and see if this is close to your HT variation. If it is, then the variation in HT is due to variation in line voltage.
This is probably the cause. There's indeed a 300-400mV variation on the mains (over a minute), which following that multiplication seems to explain the dc variation.
The PSU capacitor requirements are the same.
If it has stacked caps, and equalizer resistors not, it's a problem.
Before the power tubes begin to conduct, the voltage would rising even over 600-650V, so in the previous post capacitor voltages are not excessive.
If you put a sope to the Vb+ then you might see that the change is intermittent - following the bursts in the line AC - from polution elsewhere, and from a kind of signalling on the AC. Nothing to worry about, and it seems you have it well regulated.
