Get regulated 6.3 VDC from 6.3VAC
* 66000uF filtering? 😵 😱 You-must-be-joking.
Certainly way overkill and heaven only knows what it will do to the poor transformer not to mention the splatter from the huge but short charging current peaks. With a 1.2A load that will have about 170mV peak to peak ripple. No need for it to be that low if you are then going to regulate it. 22000uF would be more than enough giving about half a volt peak to peak ripple.
Cheers
Ian
Hi Jan,
I created them from larger Teflon turrets with a sharp knife. They are actually somewhat longer, but I now prefer my own shorter version.
I found them on Marktplaats, seller “Tauritronics”. I bought quite a few of them a couple of times.
Regards, Gerrit
Thanks Gerrit!
On getting 6.3VDC from 6.3VAC, have you considered a switching regulator? I've been using a TPS5402 for some time with good results.
Jan
If using DC, you could consider a circuit that swaps polarity every now and again. I believe the tubes prefer this.
Have you just considered a big choke pi-filter rather than a SS regulator? Pretty small drop. Other than that, I would suggest a nice little 9V transformer... Probablly a lot cheaper than a choke.
Jan
LMR14030 which I already suggested here has better specs. For indirectly heated tubes it does not make much sense to use linear regulators, chokes or other stuff. You can have similar performance with something that fits in your palm and costs less than 20 euros.
Using the MIC29303 chip there is no need for using a swithing mode regulator. Just use a Schottky bridge, the MIC29303, two resistors and two capacitors. That’s enough! Set and forget!
Regards, Gerrit
You forgot the heatsink😉
Switching regulators are about as simple. You only need to add an inductor, another schottky, 1 resistor and 2 capacitors. No heatsink and much less space.
I can confirm that the combo of a Schottky bridge with one of the MIC29xyz works very well. I use it in my standard designs if I have a mains transformer which delivers 6.3V. The MIC29xyz come in 1.5, 3,5 and 7.5 Ampère versions which are pin compatible (TO220 and TO247) although the 7,5A version is quite expensive. Just beware of the different lines with fixed/variable voltage and enable/flag outputs.
I also built an active rectifier to use instead of the Schottky diodes using the LM74670 which tested very well and results in a much lower drop than a Schottky diode. But this is overkill in most of the cases and you have to create an SMD board. Just did it for fun.
