Yes, but transformers transform impedance by the square of the turns ratio so your 70 ohm phones look like 70 x 12 x 12 = 10800 ohms.But it is.
The 12:1 ratio of the sowter transformer reflects 50Ω headphones into 600Ω on the primary side - that's the whole point of using them.
For my headphones specifically, for their 70Ω, the primary sees 840Ω.
I have used and measured this transformer and 12:1 is definitely the turns ratio.
Cheers
Ian
At Bartola Valves is more info about the same Sowter transformer.
https://www.bartola.co.uk/valves/2016/12/04/headphone-parafeed-amp-part-i/#more-5928
OK. Like I wrote, I don't really understand how you used the calculator. That could very well be because of a lack of insight on my part. But I really don't see how the way you use the loadline calculator affects the way I calculated the anode dissipation in the dc-situation (so without any ac-signal). I'm pretty sure about the validity of my calculation.Of course 113v would be at 0mA.
It's a resistive loaded stage, not reactive - the transformer isn't on the plate and does not see any DC.
It's merely a coupling device/load.
Ok. Ok.. This changes things..Yes, but transformers transform impedance by the square of the turns ratio so your 70 ohm phones look like 70 x 12 x 12 = 10800 ohms.
Cheers
Ian
So for
30-100Ω @12:1 it's 4320-14400Ω
100-250Ω @6:1 it's 3600-9000Ω
250-600Ω @4:1 it's 4000-9600Ω. ??
The calculator assumes a simple common cathode..OK. Like I wrote, I don't really understand how you used the calculator. That could very well be because of a lack of insight on my part. But I really don't see how the way you use the loadline calculator affects the way I calculated the anode dissipation in the dc-situation (so without any ac-signal). I'm pretty sure about the validity of my calculation.
So I'm modelling the lower tube only with a B+ of 115.46V and 17.9mA.
Reading Blemcowe's Preamplier Book, I'm assuming the equivalent plate/anode resistor to be (2600+100)=2700R based on his Thevenin equivalent circuit.
It doesn't appear to be breaking the max dissipation rule, although i'm now undecided on what Rk values to use since the primary impedance can vary from 3600-14400 ohms depending on what heaphones i plug in and/or what impedance matching setting i use, but 10k seems reasonable as its approximately halfway between 3600 and 14400.
If the voltage between the anode and the cathode of a triode is 115.46 V, and the current is 17.9 mA, than the anode dissipation is 115.46 x 0.0179 = 2.07 Watt. This is the anode dissipation without any ac-signal, so the situation for dc only. For this calculation the loadline is irrelevant.
Like you, I'm not looking for a fight. As far as I know, your transformer, and the way you are using it, are fine (see post #16 by PRR on this). I just noticed that you are running your E88CC's 'very hot', that's all. I'll leave at this because I'm more or less just repeating what I already wrote before.
Ok, I appreciate your feedback.If the voltage between the anode and the cathode of a triode is 115.46 V, and the current is 17.9 mA, than the anode dissipation is 115.46 x 0.0179 = 2.07 Watt. This is the anode dissipation without any ac-signal, so the situation for dc only. For this calculation the loadline is irrelevant.
That is correct.Ok. Ok.. This changes things..
So for
Cheers
Ian
In that case, I'll set up the SSRP for an RK of 620R for an Rload of 9K - that's about halfway between 3600-14400.That is correct.
Cheers
Ian
Ia will be 6mA.
This sound right?
Sounds spot on. I use 680R in my own designs. The NFB helps a lot with variable loads.In that case, I'll set up the SSRP for an RK of 620R for an Rload of 9K - that's about halfway between 3600-14400.
Ia will be 6mA.
This sound right?
Cheers
Ian
I've been crunching numbers, trying to figure out what value of Rk best serves all impedance settings:Sounds spot on. I use 680R in my own designs. The NFB helps a lot with variable loads.
Cheers
Ian
30-100Ω @12:1 it's 4320-14400Ω.
With Rk=600Ω
Zl is optimized for 8600Ω
12:1 optimized for 59Ω
6:1 optimized for 238Ω
4:1 optimized for 537Ω
With Rk=620Ω
Zl is optimized for 8930Ω
12:1 optimized for 62Ω
6:1 optimized for 248Ω
4:1 optimized for 558Ω
With Rk=680Ω
Zl is optimized for 9920Ω
12:1 optimized for 68Ω
6:1 optimized for 275Ω
4:1 optimized for 620Ω
I think Rk=620Ω to be the best compromise but opinions welcome.
Here's my Revised and expanded list:
Equation for unbypassed SSRP:
Rk=(2Rl+ra)/(u-1)
Rl=(Rk(u-1)-ra)/2
With Rk=100Ω
Zl is optimized for 300Ω
12:1 optimized for 2Ω
6:1 optimized for 8Ω
4:1 optimized for 18Ω
With Rk=360Ω
Zl is optimized for 4460Ω
12:1 optimized for 31Ω
6:1 optimized for 123Ω
4:1 optimized for 279Ω
With Rk=390Ω
Zl is optimized for 4940Ω
12:1 optimized for 33Ω
6:1 optimized for 137Ω
4:1 optimized for 309Ω
With Rk=430Ω
Zl is optimized for 5580Ω
12:1 optimized for 39Ω
6:1 optimized for 155Ω
4:1 optimized for 349Ω
With Rk=470Ω
Zl is optimized for 6220Ω
12:1 optimized for 43Ω
6:1 optimized for 173Ω
4:1 optimized for 389Ω
With Rk=510Ω
Zl is optimized for 6860Ω
12:1 optimized for 48Ω
6:1 optimized for 190Ω
4:1 optimized for 429Ω
With Rk=620Ω
Zl is optimized for 8620Ω
12:1 optimized for 60Ω
6:1 optimized for 239Ω
4:1 optimized for 539Ω
With Rk=680Ω
Zl is optimized for 9580Ω
12:1 optimized for 66Ω
6:1 optimized for 266Ω
4:1 optimized for 598Ω
Rk=(2Rl+ra)/(u-1)
Rl=(Rk(u-1)-ra)/2
With Rk=100Ω
With Rk=360Ω
With Rk=390Ω
With Rk=430Ω
With Rk=470Ω
With Rk=510Ω
With Rk=620Ω
With Rk=680Ω
I am sure that will be fine. It is important to remember when applying these formulae that ra in particular is operating point dependent. The data sheet values are correct only for the operating point at which they were measured which is usually at higher operating current that you will normally require.I've been c
Cheers
Ian
Ok, this will be my final circuit. I opted to go with Rk=390R at the end of the day as I believe this the best to serve the impedance range offered by these Sowter transformers. Ia is now 6mA.
6mA is about right I think. 390R should give you a good margin. With SRPP is is important that the optimum load is never less than the actual load so 390R is in the right direction. I keep forgetting you have a lowish HT.
Couple of final points. Do you really need R2? What is the purpose of C14 and R46? And also the purpose of C7 and R23?
Cheers
Ian
Cheers
Ian
I've been running Spice and watching the SSRP's output very carefully - the stage's push/pull is best balanced at the calculated Zload [Rk=(2Rl+ra)/(μ-1)] and becomes ever more unbalanced the further away from the calculated ideal Zload, operating less and less as a push/pull and more as a simple single ended stage.6mA is about right I think. 390R should give you a good margin. With SRPP is is important that the optimum load is never less than the actual load so 390R is in the right direction. I keep forgetting you have a lowish HT.
Cheers
Ian
According to Merlin Blencowe's Preamplifier book and his online "Optimized SRPP" paper.
https://drive.google.com/file/d/147K_BhXuxFv0d1c4u-RkxRZUKO2ry_gf/view?usp=drivesdk
He suggests using Ra @ 2Rk to further balance the SSRP, ie, the "pushing and pulling" at the calculated ideal Zload but it's not absolutely necessary for high μ tubes.
I can confirm this to be true from observation of Spice outputs, by comparing the signal amplitude (current) at V2's cathode just above the tap and that of Rk2, beneath it.
C14 and R46 I lifted off of John Broskie's TubeCad site - his "Akido Mojo".
It injects a portion of the Remaining B+ noise into the cathode, canceling it out.
Kind of like NFB for B+ noise.
Every time I change the RK resistor values and the quiescent current I need to recalibrate it and adjust R46.
I do this empirically in SPICE by disconnecting the PSU caps and idling the circuit while zooming in on the flatline output after the power stage's coupling cap - it's very effective at flattening the quiescent B+ even with the caps disconnected.
My amp is dead silent as it currently stands.
I keep forgetting you have the advantage of a fixed load so optimisation is a realityI've been running Spice and watching the SSRP's output very carefully - the stage's push/pull is best balanced at the calculated Zload [Rk=(2Rl+ra)/(μ-1)] and becomes ever more unbalanced the further away from the calculated ideal Zload, operating less and less as a push/pull and more as a simple single ended stage.
OK, understood.
I use 6922 tubes in an SRPP output stage in my audio mixer designs. I have a variable load depending on what routing is selected and if the direct outputs are used or not and so on. Basically the load can vary from from moderate to heavy. My version outputs +26dBu into a 600 ohm load with a 300V supply (that is 400mW) using a 2:1 output transformer. There would typically be 20 or more such stages in a mixer quiescent current has a big impact on the power supply so it is set to be sufficient to drive the worst case load rather than to optimise the SRPP. Dissipation is also an issue with so many tubes in a smallish enclosure.
Of course Merlin would say this is exactly the application where you would NOT use an SRPP.
Cheers
Ian
- Tubes / Valves
- My Newly Scratch-Built Tube Headphone Amplifer
