Shout out to Victor, not Elrog
Maybe it’s just bad luck, but after a little more than a year my sublime sounding Elrog 300B tubes died inside my TU8600. I confirmed this with the guidance and support of Victor. Through calls and emails and a pro bono shipment of 300B tubes for testing we concluded that the Elrog tubes had failed. I can’t afford nice new tubes right now, but when I can, you can be sure they won’t be Elrog and they will be from Victor.
Just following up here… With new tubes, all test points measured within range - including the two test points near the power tubes that target 5V. I agree it is strange that both Elrog failed within hours of each other. At first, I discovered one channel was quiet. I swapped the tubes and then either immediately or very shortly thereafter both tubes were very quiet. At that point I measured the test points, found an issue, and then resolved the issue after installing good tubes.
