Replacement Peavey CS-800 Power Transistors?
Excellent! That's what I see here also. Looks like the RCAs may??? be original part numbers. I don't know the accuracy of this cross reference (attached).
Taken from here:
https://www.audiolabga.com/pdf/PV_Semi_Cross_Ref.pdf
That IS RCA’s MJ15024 then. They did make one for a few years - it is in one of my old data books. Spec is exactly the same as the Motorola.They are parallelable if they are close in vbe at the same current. Better if they are all the same wafer lot, but in the old days there was more variation within a silicon wafer than there is lot to lot months apart today.
