It would depend on the amp. Most amps are likely designed to take at least the maximum common charging voltage of about 14.5v.
How much voltage can an amp input handle? 14volts or 15volts or 17volts?? 20volts???
Depends on the amp, but few amps need more than 2 or 3 VRMS for full output.
If you mean how much input voltage could damage the amp input circuitry, that depends on
the particular amplifier design.
Sorry voltage coming into the B+ from power source and B- from power source weather it be a car battery or power supply?
You didn't give much background information. Is this for testing during repair or for long term use in a vehicle?
Overall just wanted to know if any amp could handle past 15v. Basically I just wanted to setup a music station in my garage. I have a laptop power cable but output is 19v and wasn't sure if amps can handle past 15volts. I guess I can modify and make it output 15volts. Thanks
Laptop power supplies typically have only about 3 amps output.
A standard desktop computer power supply is better suited. Virtually any desktop supply will provide 10+ amps of current.
I have seen on youtube how to modify those. I think i have one from my old computer upgrade. Do you have any advice on how to modify or just follow the youtube videos?
There is no need to modify it. It has a 12v output.
The mods are for people who want an adjustable supply which isn't needed.
You should have said this in the first post 😉Overall just wanted to know if any amp could handle past 15v. Basically I just wanted to setup a music station in my garage. I have a laptop power cable but output is 19v and wasn't sure if amps can handle past 15volts. I guess I can modify and make it output 15volts. Thanks
We still don´t know which amp are you talking about. 😎
IF a typical Car power amp, forget it, they are typically power HUNGRY. easily tens of Amperes, will explode or at least shut down your supply, which having meager 3x19 VA=57VA nominal capability means it can only feed a 35/40W RMS amplifier.
Search EBay and such, there are many amplifiers which are happy with a 19V single supply and which will fill your garage with Music.
Why are you running an amp at 15v just to have music playing?
The high voltage can lead to problems with capacitors, regulators... depending on the amp.
- General Interest
- Car Audio
- Question about voltage??
