STK modules
A friend asked me to fix her Toa model KD-1 integrated combo amp. She plays Cello in a local quintet.
This unit has one mic input, four RCA type inputs an amp, and a 12" speaker with a secondary small cone (forgot what hey are called) attached to the same voice coil. TOA had a good rep back in the day,
Anyway, the power amp is bad and it has one of those dreaded (IMO) STK modules which is a complete audio amp in an lage hybrid IC package.
I've only heard how unreliable these modules are. I suspect the run away thermally?
It has the STK 3046V. specifically which doesn't seem to be available.
What's the scoop on these things. There appears to be many variants. Do they all have the same pinout?
Should I attempt replacing with a different variant.?
If I owned it, I'd replace the module with a class D amp I suppose. I'm not willing to put that much time in someone I'm working on for free for though.
Replacing the whole power amp section with a new amp module may be the simplest and easiest fix. If you do locate a new STK module it will probably be a FAKE, and even less reliable than the original. The construction of those original modules is wrong on so many levels that it’s a wonder they last as long as they did. Modern reproductions (fakes) are even worse.
There has been success with people building “replacements” for them out of discretes, using construction techniques and proper parts which are reliable, but it’s a lot of work for a freebie. Can’t say I recommend doing it unless you were *really* attached to that amplifier.
How much supply voltage does that power section use, and what speaker impedance? That will give you some idea of what you could build into it in place of the STK module.
The STK 3046 is not on the net, please check the number again.
Those are mostly two amps in the same module, so it may be bridged stereo.
You have a single set of speakers, 12" cone would be about 40 watts RMS...check the supply, and get an appropriate Mosfet or Class D module. Check for mono in and out levels.
Check the power supply first, STKs have been known to take out power supplies too...so that also may be needed.
Except the LM1875, there is a shortage of Class AB chip amps, and many Class D from China are also fake chips, though some are said to be of good quality.
On the cheap, you can find an old amp with one working channel, and use the inner parts for this one.
Or buy an old or new party speaker. New will be $40 and up.
Those are speaker with amp, with wheels, some have a battery too, you can go to the beach with them.
Ideal for a musician, those are intended for travel and rough use.
