Is this Cap any good for output coupling in headphone amplifier(OTL)?
Is this Cap Sic-Safco 470uf any good for output coupling in headphone amplifier(OTL)?
For Headphones impedance 62 to 600ohm!
All I can find out about those Sical Sic-Safco caps is that they are electrolytic.
If they are old, then I would not use them.
Electrolytic caps have a shorter life span than plastic film capacitors.
Therefore, if I was going to purchase electrolytic capacitors, I'd buy new, recently manufacturer ones, not vintage ones.
I hope that helps.
How about...?
https://www.mouser.com/ProductDetail/Nichicon/UPW2E471MRD?qs=oQYsPLWZnc0O2NTmRKXI/Q==
470uF 250V
+105C rated
8000 hrs service life rated
low impedance
Not too expensive
-or-
WIMA DC-Link polypropylene caps are available in 200uF 400V. That would be ideal except that they cost 5X what the electrolytic cap costs, and it looks like you have to special order them. But you're only using two for a stereo amp, right? Might be worth it...
On the description for Sic-Safco its says they are new which means nos, I asked the seller if they were tested but no response.
I also found these German branded caps, ROE ELKO, russian seller sent me offer $9/£6.70 for 2pcs. did anyone used them for coupling?
I'm still waiting for my Peak ESR70 then I'll test them.
The issue with 'testing' is that is quite involved with caps and and Arduino attached to a screen doesn't quite demonstrate it's all great with the cap.
1. impedance vs frequency
2. leakage
3. voltage applied
A cap may give you one set of responses at low voltage but a different set at higher voltage, especially where leakage is concerned. Testing a 600Vdc cap at <1V may not indicate its failure. At least without some high degree of sensitivity (ie Carlson Labs style).
I'll be interested to see how you get on with the Peak ESR meter. Looks like a handy addition to the standard L-C-R measurements from a multimeter.
Too large, not gonna fit inside my Woo audio Wa 2, I bought Mundorf mkp classic 330uf(250v) without checking the diameter(62mm), now i don't know what to do with them LOL
Hehe yep - the space for a transformer is taken up with caps. Just a different form of metalwork.
The size is a problem, although with a can - as long as the can itself can be is grounded vs the potentials applied to the pins. Last thing you want is 250Vac on one side of the cap at the other sat grounded to the chassis.. Those WIMA caps metal case and bolt are specifically designed to be earthed/bolted to chassis chassis. In principle I like the idea better given you can keep them cool by being exposed above the chassis. The Mundorf don't have that luxury without some additional metalwork.
I was thinking more along the lines of this:
I like being able to get in the car, hit a button, and have a working car with no need to "warm up" the engine and no choke. I also like the fact that a modern 183 CI engine makes 382 HP, which is almost as much as that 426, but more driveable and 1/2 the fuel usage 😀
I don't really trust old electrolytics, even if they're NOS. I'd spring for a new Kemet or Epcos cap, rated at the B+ voltage or above. I used Kemet 220uF/350V in my headphone amp since I have 32 ohm phones, but you can use a smaller cap with higher impedance phones. I also bypassed the electrolytics with 2.2uF film caps.
UK 1973 - Ausin Allegro (The Austin Allegro... - It never stood a chance - Not PS2 Grand)
Yeah.. err. No. ... no. no. no.
