inviting input on relay controlled power and muting
I'm repackaging my old turret-board Transcendent Grounded Grid and want to delay the HV to allow the tube warm-up and keep the output muted until HV is up.
It has two hv supplies: +200VDC and -200VDC. Those and the heater supply are all fed by their own secondaries from a single transformer. So if I delay HV, it has to be done on the secondary.
I have 4 channel relay board connected to an Arduino. The relays are rated for 10A 250VAC.
ANMBEST 2PCS 4 Channel 5V Relay Module with Optocoupler High or Low Level Trigger Expansion Board for Raspberry Pi Arduino
relay 1: Secondary 1 to NO - COM to +200VDC PSU
relay 2: Secondary 2 to NO - COM to -200VDC PSU
relay 3: Signal Output 1 NC - COM to ground
relay 4: Signal Output 1 NC - COM to ground
Relays 1 and 2 come on at 30 sec, relays 3 and 4 at 40 sec. I have a basic sketch that seems to work.
Code:
#define relay1 7
#define relay2 6
#define relay3 5
#define relay4 4
void setup() {
  Serial.begin(9600);// setup Serial Monitor to display information
  pinMode(relay1, OUTPUT);// connected to Relay 1
  pinMode(relay2, OUTPUT);// connected to Relay 2
  pinMode(relay3, OUTPUT);// connected to Relay 3
  pinMode(relay4, OUTPUT);// connected to Relay 4
  Serial.println("wait for 30s");
  delay(30000);
  digitalWrite(relay1,HIGH);// turn relay 1 ON
  Serial.println(" relay 1 ON");
  digitalWrite(relay2,HIGH);// turn relay 2 ON
  Serial.println(" relay 2 ON");
  delay(10000);
  digitalWrite(relay3,HIGH);// turn relay 3 ON
  Serial.println(" relay 3 ON");
  digitalWrite(relay4,HIGH);// turn relay 4 ON
  Serial.println(" relay 4 ON");
Am I missing anything?
Are your relays rated for switching high DC voltages? Few are.
He appears to be switching "AC", before the rectifier. I agree this might even be worse than switching straight DC.
AC will "pause" 120 times a second. Any arc will go out.
Straight DC above a few volts, the arc may never go out, unless the contacts are designed with blow-out or deflection features.
Switching the input to a rectifier and capacitor can be a HUGE turn-on current. The kind of thing that other builders go to great lengths to avoid.
I don't follow. The 200V PSUs receive no AC until the relay is energized by 5VDC and signal from the Arduino and then they stay on until power is cut.
Looks fine to me. relays rated for 250 and you're switching 200. I don't get the DC above a few volts comment. Nearly every relay has DC ratings for contacts though usually never as high as the AC rating. Relays switch heavy loads constantly for many years. I finally had to replace a few in my 30+ year old garage door opener.
Thanks. The secondaries are only 120VAC so well below max. The PSU is a voltage doubler.
Code:
#define relay1 7
#define relay2 6
#define relay3 5
#define relay4 4
void setup() {
  delay(30000);
  delay(10000);
Yes. You should short the output at power off before the B+ has gone. And
don't bother with delaying B+ .
Code:
#define relay1 7
#define relay2 6
#define relay3 5
#define relay4 4
void setup() {
  delay(30000);
  delay(10000);
No? I thought delaying to allow tube warmup was supposed to prolong tube life.
False. But long periods of filement AND no B+ may cause "cathode poisoning" where an isolated layer is built in the cathode surface. ( long means hours )
B+ applied at power on is no danger for tubes operating below 1000 volt.
I've seen schematics where the output muting is a relay connecting the output to ground. This must be on the output side of the coupling cap of course. This means you aren't sending signal through a relay contact during normal operation. You could use a signal relay instead of a power relay.
I'm in the "no need to delay B+" camp on this one.
