Barbouri implemented a nice PCB and design of Scullcomm's Milliohm meter.
Milliohm Meter Version 1.5 - Barbouri's Electronics Projects
scully incorporated it into an update:
Milliohm Meter Update – Scullcom
I have just made the Scullcom version using the 1.4 boards. (didn’t notice there were some 1.5’s!.)
Just finished it and its working fine. I ordered the 1.4 boards by mistake but implemented the 1.5 changes.
Getting hold of the 2V voltmeter (YB5145B) was difficult to find in the UK. I could only get 200mV version. After a lot of mucking about I found a way to convert the 200mV to a 2V version.
1) Remove 2 resistors, RA and R1,
2) Put a 100k at R1 and a 11K at R2.
3) Then change the decimal point link to 2V.
(It should be 10K at R2 but I couldn’t get the bourn pot to set it to 1.999 Volts.)
China seems to have a lot of 200V versions, suspect they could be modified the same way.
I have 2 boards and 2 modified Voltmeters if anyone in the UK wants to have ago.
(I also changed the 5V voltage regulator (MIC39100-5.0WS) because the one specified seems to be either discontinued or a very long wait, C10 becomes a 1microF Tant and C5 a 220microF electrolytic with a > 100mOhm ESR for stability reasons for this chip)
....... It should be 10K at R2......... ......
It should be 11.111,11..k
10:1 divider with 100k on top. N-1 is 9. 100k divided by 9 is 11,111.1111111Ω.
Yes, these are all 199mV meters so the "200V" model is only different with a 1000:1 divider. 1Meg and 1k could be good. (1Meg and 1001.001,001.. or 999,000 and 1000 would be gooder but.)
Thank you, that explains a lot 🙂, the photo I had of the 2V one had R2 at 1002, suspect tolerance of this resistor allowed the pot to bring the meter into spec..... but who knows....
Just finished it and its working fine. I ordered the 1.4 boards by mistake but implemented the 1.5 changes.Milliohm Meter Version 1.5 - Barbouri's Electronics Projects
milliohm-meter-update/"]Milliohm Meter Update – Scullcom
LOVED that project, very well designed and made 🙂
