Speaker builder estate sale
PICTURES HERE: LOTSO SPEAKER STUFF - Google Drive
I recently purchased a bunch of speakers / drivers and speaker building parts from the estate of a local speaker builder. I intended to pickup where he left off and build some cool speakers myself during all the COVID downtime, but it turns out I'm way more busy than I thought I'd be....so it's time to pass this opportunity on to someone else. This seems like the best place to do that.
There's way too much stuff to list individually. Most of the drivers are older, sorta vintagey stuff, some older Scanspeak, Coles, Polydax, etc. and some really cool and rare gems. There's just WAY too much stuff to list, and if I was going to bother taking the time to inventory everything, I might as well go one step further and list it all for sale and make way more $. I just don't have time. Maybe you do? Or maybe you'd like to use these for projects?
I'm thinking the best way to sell stuff is by category and just take some offers. No reasonable offers will be refused. I'm just trying to clear out some cabinet space and hook someone up who can put all this stuff to good use!
NOS Drivers:
These are NOS drivers in boxes, never opened. There's an insane amount of them.
15 cases and 4 individual boxes, or 94 total of the YD180-8P01 low/mid drivers. Don't let the Chinese branding fool you, these appear to be very high quality drivers. The magnets are huge with cast (not stamped) housings, and they are HEAVY for their size. The only info I can find about them online is the following:
Model: YD180-8P01
Impedance: 8 ohms
Rated Power: 60 watts
Freq Range: 50hz-6000hz
Sensitivity: 89±
Q: 0.52
Cabinet Volume: 18 liters
Effective Vibration Radius: 65mm
Vibration Quality (?): 11.4
Apparently these were made by "South Whale". The only speakers I can find that utilize these drivers (or at least nearly identical South Whale 6.5's) are here: Xy-020 6.5 Inch Hifi Speaker Vifa Dx25+south Whale King Mid Bass 8ohm 30-120w 87db - Buy Full Range Speakers,6.5 Inch,Bookshelf Speaker Product on Alibaba.com
Here's a thread on HifiDIY with some info about the drivers specifically (you'll need to translate from Chinese): HIFIDIY- - Powered by Discuz!
As for the HF drivers in the boxes, I can't really find any info about them, but they are clearly meant to pair with the LF drivers, and even look similar to the Vifa tweeter in the Alibaba speaker. The model # on these is DT516-FS.
There are 5 cases of tweeters, and 10 individuals, or 100 total drivers.
So you'd have enough drivers here to make at least 94 speakers, with a few extra tweeters left over. *EDIT: I think I'm going to keep a pair to install in the cabs I have. So possible minus 2 from this list.
I have no idea what to ask for these, so make an offer? Keep in mind these are very heavy, so shipping will be a factor. Local pickup around Seattle would probably be easiest.
PICTURES: LOTSO SPEAKER STUFF - Google Drive
Other misc drivers
There are several boxes/bins of misc drivers, some loose, some in boxes. This is where you'll find some oldschool Scanspeak, Seas, Coles, Vifa, Polydax, McFarlow, Visonik, Intervox, etc. There are some Chinese ribbon tweeters that look pretty cool and lots of unbranded drivers. I've tried to keep the cones protected as much as possible, so for being in a big pile, they're actually in pretty decent shape for the most part (I had to toss some that were obviously toast). There's no way I'm testing all of these, so it's a crap shoot. I can't really guarantee condition on any of this stuff, but especially the loose speakers. I'm guessing most of them work just fine, especially the ones still in their original boxes, but I'm sure there are some dead ones as well.
Capacitors, resistors, misc.
There are a ton of caps and resistors. Resistors are of the large ceramic variety. There is a huge bag of 4ohm resistors, and some misc 2ohms too. There are a ton of 10uf 50v caps, one bag of 2uf 200v, a bag of 6uf 50v, and some large white caps that aren't obviously labelled but measure 20uF bipolar on a calibrated Fluke 87V. I have no idea of how much of each there are, just A LOT. There is also a bag of some kind of connector I'm not familiar with, and a bag of misc components.
Xformer/inductor stuff
This could probably go along with the above lot for making crossovers, but it's kind of a seperate category, so here goes. There is a giant, and I mean GIANT box of transformer housings or layers (not sure what they're technically called). This box probably weighs about 100 pounds. Shipping would not be fun....but if you really like making your own transformers, it might be worth it. Again, local pickup in Seattle is probably going to be way easier. This "lot" could also include a bunch of misc transformer/inductor wire in different gauges (see pics).
Speaker cabinets and grills:
Probably not worth messing with...I'll probably just throw these in with any of the above groups if someone wants them.
There are too many photos to upload here, so they can be viewed in this Google Drive folder. If anyone is interested in any of these items, or the entire lot, shoot me an offer! Thanks!
With a little modification, I can get the YD180 and DT516 drivers to fit in these cabinets I have, so I think I'm going to keep a pair of each and throw them in these cabs with some generic crossover to see how they sound....which means there'll be enough drivers to make 92 speakers 😉
