I have fired up my SSE and there are a severe hum in the speakers, I still hear it when I leave the room with the door open.
This is my first build and the setup are:
The amp are now configurated in triode without feedback (see pict)
The board are grounded via the PCB together with the zero point of T1, the center of 375-0-375.
Incoming signal are grounded via the PCB at the IN-connectors (pin 2 & 4)
Speakers are grounded via the PCB at connector T2&T3 sec
I have not grounded the power and OPT shields, it is on my ASAP to-do list.
Measurments:
Things I consider to try out, in specific order
Will negative feedback help?
Shifting the sec of OPT?
I’m considering a choke. However are this related to cost (I have already exceeded my budget) and lead time, if I order today will I not receive it until next week, the weekend will be spoiled. Therefore is this not my primary solution, more like a backup.
Anything else, what have I missed?
- Power: Hammond 374BX
- JJ 5AR4
- JJ 12AT7
- Russian 6L6GC equivalent (see pict)
- OPT: Edcor GXSE15-8-5
- No choke, R1 = 150 Ohm
- Speakers: No name 8” + 1” tweeters from the 1995-isch.
Measurments:
- B+ = 454 V
- R17/R27 = 680 Ohm, wired to the outside of the PCB for easy exchange during the test period
- U_R17/R27 = 35 V
- I = 35/680 = 52 mA
- P = (454-35)*0,052 = 21,5 W
- VAC in idle on the OPT-sec are 24 mV on left channel and 54 mV on right channel, measured with my DVM.
- Ground the casing of transformers
- Twist power wires (5, 6,3 and 375 V)
- Add a capacitor at T1 red/yel-GND
That layout is on a wood base?
So there is no shielding plate under the PC board?
And no shielded wiring of the input wiring?
So of course it will pick up hum.
Put a sheet of aluminum under the PC board and ground it to the PS ground.
Twisted the wires.
Didn't have any extra 500V caps, have to order that. 100-300uF?
Tried to shift OPT
Tried feedback, both negativ and positive to be shure.
NO progress
The humm are initially 100mVAC, goes down to 20-30 mVAC after few minutes.
The frequency are 100Hz (grid are 50). Therefore do I conclude that the origin are in the area of the rectifier or insufficient capacitor.
Yes, I also tried to remove the rectifier and run on diodes. No change.
Tried to shift OPT
NO progress
This can't be the first SSE build on wood.
Please explain how a ground sheet below the board would improve the situation?
Are you using new, low ESR filter capacitors of adequate uF value?
Ordered recommended or eqvivalent from Digi-key. Any perticular capacitor in mind, i can look up the specific item number if you tell me the position on the PCB.
The largest ones, close to the rectifier tube.
Can you post a scope picture of the hum signal ?
Measured on the sec of OPT.
Hopefully attached...
Switch time base to a scale to read just one to two wavelenghts - frequency is ?
One wavelength are 10ms => 100hz.
Sending an 100Hz signal to input matches the hum. 50hz are significant lower.
- More Vendors...
- Tubelab
- SEE: Severe hum
