Chassis tube holes rubber grommet/washer
Joined 2011
I know it is a weird question. Do you know what is the name for those rubber grommet rings they put on the tube holes in the chassis? Trying to find, but for some reason fail to do so. Would appreciate it you can point me in the right direction.
for the look basically. I have a black anodized chassis, so holes look bare aluminum -- not pretty. So I was thinking something like this will look better.
Making large holes in chassis: Use a step drill to get close and then use a forstner bit on slow in the drill press ( I'm using it with a predrilled guide in acetal clamped, it also prtects the surface against the swirl coming from drilling) to drill the final hole.
Alternatively use a woodrouter with a guide to cut it (I'm using it to trim the aluminium to size, take only thing custs at a time, 1/32" or so). Up to 3/16" use tungsten, above 3/16" use HSS. Lubricate.
Rubber grommets: On very early radios that had low audio output the transformer noise could be irritating. I've come across a couple of old Philips radio's when I was a teen that had the power transformer mounted on a /washer - rubber grommet - washer - nut/. Transformer noise drops down a lot.
Enjoy
EL506
PKI,
I think what you are looking for are Heyco bushings. They're a good coverup if you have ragged holes. I've used a Starrett hole saws a little undersized then a Dremel to get the final size for the bushing.
Mouser has them in many sizes. Search number 836-2182 for instance. Go oversized 1/8" all around (1/4" larger diameter) for small tubes, perhaps larger for power tubes.
S.
