What DAC?
Hello,
I've built a player (or several before 🙂 with RPI+moOde >> I2S FIFO >> serial convert >> AD1865 >> I/V trafo >> ECC82. That is my main DAC, but now I need one for headphone music listening. I would use an XMOS / Amanero USB >> I2S board than an I2S DAC.
If I like AD1865 the most, what modern DAC would I like now? AK or ES ? Which version?
As far as DAC chip, which is the best nowadays for mainly acoustic music?
I have a Chinese AK4497 board what I do not like. I guess it is the opamp output, but It is rather harsh. I do not like to wash away details, but for me, quality comes when it sounds pleasant and detailing in the same time. Of course, it could be that the DAC chip is just a copy also, so I do not judge based on this, but I need help which DAC should I go with?
Thanks a lot!
JG
well TDA1541A, TDA1540, PCM56 😉 have not to be forgotten if talking about pleasant be it NOS or not. AD1862 is better imho than the AD1865. At least my ears say so.
Miro made a headphone board with the ad1862 with headphones driving capacity (oaps chose for the job) and thanks to a member on the GB you can source genuine AD1862 from Rochester warhouse.
It's true with Ebay and Chifi that you never know if chips, oaps, caps are genuine, so better to choose for reliable brands if you don't want to DIY whatever the dac chip brand -AK, ESS, Cirus Logic, etc- , there are brands cheap enough for not wanting to take risk : Topping and so on. They choose the best oaps avaliable today for driving headphones : op1656, 1611/12, etc.
In your shoes I will go for the AD1862 if you don't need portability
Hello,
Well, when I bulit my last ad1865 based DAC (NOS), that was already out of production. That was a few years ago.
I thought there must be new, at lest as good as chips with better support. Feeding it is also a problem. An I2S chip would be more convenient. I just do not want to **** against the wind.
… but, if there is no real, modern alternative, I’m looking at how to feed it.
Thanks,
JG
Hello,
Out of production, yes, but still available. Production should only be an issue of concern for DAC box vendors.
I thought there must be new, at lest as good as chips with better support...
Yes, there are. However, that is besides the point, I think. The primary issue appears to be sound character. Which, cannot be accurately predicted only from knowing the DAC chip, IMHO.
Feeding it should not be an issue, use the JLsounds
I2SoverUSB - I2S over USB Audio
Hmmmm.... Thank You!
I did not know that XMOS XU208 directly supports the 18bit data format what the AD1865 digests. Only this product does it or all XMOS XU208 in general?
I'm going another route than. I stick to the AD1865, but need an USB receiver with 2 xtal for low jitter output and data format for the AD1865. I also have an older Amanero receiver.
I thought these boards only support I2S. Now I dig into this.
Thanks !!!
JG
I have place for surface mount termination resistors right at the DAC chip input legs.
With Ian's PCM board, I've used to experiement to find the value where ringin and overshoot is the minimum, but the corners does not start to get rounded yet.
For this, my 50MHz Rigol oscilloscope may not be enough (yes for the rounding, but not for showing the ringing). I've used t have access to a high speed scope which was excellent for this, but I can not use that any more.
It would also be more simple just to go with the specified termination rather than exerimenting. I wrote to JLSounds.
Thanks,
JG
Notice than in the Miro1360 member thread about ad1862, there is also on the first page a link to the gerbers of an AD1865 pcb version. It's free, it works, you have just to download the gerbers and upload them to a pcb makers, one is advised in the thread that is cheap. So you may want to try at the same time the better imo AD1862 dac chips pcb (two chips needed they are mono).
so, the JLSounds interface arrived and I just try it.
On the bench, it works fine.
anjump123, I appreciate your suggestion!
Now I'm looking at other threads to learn what to put on the output. I've always used Lundahl interstage transformer (the 200 Ohm I/V resistor on the transformer legs, no cap), with success, but on this one I will not use transformer and no tube output amp.
I was not working with opamps since ... do not know, long time ago. I have no idea what is good nowdays. I will need two stage. One after the I/V resistor, than a volume pot, than another one before the headphone amp.
Thanks !!
JG
