A novelty dipole air motion tweeter
We handcrafted the tweeter recently, the test result show as below:
992968d1635231743-novelty-dipole-air-motion-tweeter-fr-png
The tweeter is designed for below purpose.
1. A dipole radiation tweeter can work in 3-40kHz, it has a round base so it can mount into your dipole baffle or just put on the box/baffle.
The tweeter has really high sensitivity in its range, about 98-99dB/2.83V from 3-40kHz (even in 4Pi space without addition baffle). The impedance is about 6 ohm (frequency independent).
2. A supper tweeter to work with current commercial system, or your diy projects, due to it has really high sensitivity, flat impedance curve and excellent extend, you can easy design the crossovers, a single capacitor and L-resistor is well done in many conditions.
The THD shows some peaks
Although we are working on improvement.
Anyway the tweeter is not a normal design, the resonance internally in the driver maybe cause little higher THD, can we get some compare test result from here?
You can find some distortion measurements I made on dipole AMT tweeters such as the Neo3/GRS PT2522 and Aurum Cantus AST2560 in this thread:
measurements of nude ribbons and a dome-dipole
If you can revise the design to make the usable low end at least 2kHz that would be a much more comparable, and more useful, product even if sensitivity must be lower.
Thank you! I will pay time to study the result.
Sure but maybe not now, although I realize that this is perhaps one of the most competitive supper-tweeters in the world----consider its very good extend and high sensitivity, well usability, especially above 10kHz the THD become less effect IMO.
let us make it more stable, and maybe better performance.
