I recently got a box of old NOS RCA tubes, with 2 each of 75, 76, 42 and 80. I was thinking a small SE 42 amp could be fun to try, for a whopping 4 watts in pentode mode.
The 76 is apparently a very nice tube, maybe a little low gain if I'm going to use feedback or try the 42 in ultra-low power triode mode.
That leaves the 75 with a mu of 100, but with very low current capability, 1 mA seems to be the limit, with a total of 2.5W dissipation. Can the 75 be suitable as a driver for the 42? I've tried plotting some different load lines but as a total tube design noob (I've only built other's designs) I'm not sure if it's feasible.
Ri=91k, so anode load resistor must be equal or greater than 270k.
Suggested anode voltage is 250V, current 0.8mA, so B+ at least
250 + 216= 466V.
Output impedance is 68k.
It's not a forcefull driver.
p.s. Similar than 6SQ7, 6SQ7GT.
250 + 216= 466V.
So that's almost 12AX7 territory. I could try running it at a lower voltage, The Tung-Sol datasheet also suggest another operating point with a 100V plate voltage and a 250K load resistor. The voltage gain is lower but still a fair bit more than the 76, and I could possibly get away with the 300V B+ I had planned for the 42s.
Thanks for the reminder about the 6SQ7, I've seen it mentioned as an equivalent but I haven't really looked it up 🙂
There are 100's of old radios with that combination, e.g. this one picked at random
https://www.radiomuseum.org/r/republic tl6c
The 2A6 is similar, and I have this circuit which is meant to be highly regarded, but cannot remember where I sourced it ...
I know I've seen that 2A6 schematic before somewhere, but I couldn't find it now. Around 300V on the 2A6, so it definitely looks like something I could use, thanks!
I use a 6SQ7 to drive an EL34 and it sounds really nice.
I'm doing a YouTube build series on that amp right now. I think a 75 would work just as well with a few limitations. I'm running them fairly hot at 250V -1.8V bias with 1.25-1.33mA of current, they don't seem to have any problem running there. The 6SQ7 does have a higher max plate voltage of 300V vs the 75 at 250V, the diode is rated at 1mA but the plate can handle more AFAIK. As long as you are driving a tube that can run with a 500K grid leak resistor and doesn't need a ton of swing, you should be fine.
BTW the 6SQ7 datasheet has a nice chart of operating points/resistors to use for different loads and the gain needed.
Skunkie Designs EL34 6SQ7
6SQ7 vs 6SF5
Have you thought of using 6SF5? (Cool video!)
Yeah, the pinout is different but likely could use the same circuit for either. Shame they don't share the same pinout for the triode section!
@stephe :
Thanks for the tip about the 6SQ7 chart! I saw the thread about your amp and was meaning to ask you if you’ve tried it at lower voltages. Looks like I can get something useful out of it with 300V B+.
@stephe :
Be nice if every tube data sheet had that 🙂 The RCA manuals have a neat chart like this for most tubes too. These tubes don't have a lot of info on using them in modern designs, but they sounds GREAT.
Time for eBay sellers to come up with an adapter for them!
- Tubes / Valves
- 75 tube as driver?
