We have the below setup
Mixer: Soundcraft signature 16
Amp: Crown xli 2500
Speakers: 2 x JBL JRX 215
+ sufficient speakon and xlr connectors from neutrik
Now, I need some guidance on choosing the right cables for connecting all these. I am planning to solder these connectors by myself. Please suggest the cable specification.
Amp: Crown xli 2500
You want a shielded 3 conductor wire in 22-24ga for the balanced interconnects, something like this.. Mogami W2549 Neglex Long Run Microphone Signal Cable 1 ft.
And for the speakers you want a 14-12ga 2 conductor wire, standard electrical cable works well for this but you can also buy cable with a thinner outer jacket that is easier to handle. Audtek 13 AWG 2-Conductor OFC Portable Speaker Cable 1 ft.
I used to make my own cables, then I discovered that the materials cost me just about the same as buying the finished cables. I never made another one. Store-bought even comes with a warranty.
Having thought of it, yet decided to do it by myself out of interest. Also, we conceal it. Therefore ready-made cables are out of scope here.
For SpeakONs which are screw-terminal that doesn't make any sense as people cheap you on the copper, and you need that copper - watch out for CCA and avoid when buying wire. They are quick and easy to make compared to soldering XLRs. Also the length needed for speakers is usually bespoke anyway.
In my case, I was buying connectors and wire from the same place I bought my finished cables. Same materials.
Ok now I got 14 AWG (2.5 sq mm) 2 conductor wire.
As I already mentioned, I have 2 JBL JRX 215 which i run the above said wires to both the speakers. I take the i/p of both the speaker wire and twist connect the other ends (+ve&+ve , -ve&-ve) and i connect it to speak on connector to +1 & -1 terminals and plug it into the o/p of CH1 in amplifier.
Similarly I connect another pair of old speaker to CH2 of amplifier.
In this case, what amplifier mode should I select? Stereo or parallel?
How are the speakers being used, one set for FOH and the other for monitors? If so stereo is the correct setting.
Stereo(dual channel) is still the correct setting, the speakers in the middle of the room will have to be delayed so the amp channel driving them needs a separately processed feed.
Okay and how do we delay it and how we give them a separately processed feed?
(A noob query maybe)
With your digital mixer or an external processor. 😀
Based on your other threads I don't think you have either of those so you may have to rethink. If you put additional speakers further out in a room and feed them the same signal as the main PA they will actually add reverb to the space and make things less intelligible.
- Live Sound
- PA Systems
- Cable specification for Speakers & Mix-Amp Connection
