and what do you recommend they are adjusted to?
Precisely where they are now, i.e. don't adjust them if the unit is untampered.
AFAIK There's only an schematic available for this product with no setup adj details.
Hi MikePP
I do not want to adjust without knowing what to measure and what the setting should be, just thought I would like to check the setting and if anyone knows what they adjust and what the settings are then it could be nice to know and check it.
I do not want to adjust without knowing what to measure and what the setting should be.
Good 🙂 , some people see a pot and think what if I twiddle that and do just that 🙄
They then see another and twiddle that, and before you know it you have a completely misaligned/badly adjusted product, that can sometimes take lots of time to get back to where it was, it's optimum or designed setup.
When I glanced at the circuit over earlier, it seemed four of the pots were simply for biasadjustment in a couple of separate amp sections. I couldn't find the other two pots though in the short time I looked (busy day)
You could always fire a email off to parasound and ask..... they'll probably say mind your own business or why do you want to know.... but at least you will have asked those who will def know the procedure they set up.
