How much bass EQ do you use?
Visaton FRS 8M in sealed Ikea salad bowls, and 9dB at 55Hz, room peak at 50Hz fills in the last bit. I live in an apartment, so can’t have high SPL without annoying the neighbours, so it suits us just fine. DEQ and limiting on the amp means that you can turn it up surprisingly loud without anything sounding nasty, even if it is a bit thin when loud
Brian
Thanks for your reply. I'd like to try those salad bowls, did you make a sphere out of them? That little driver has decent excursion.
Producing bass is about moving air, so even an array like that will run into trouble if you're asking it to do loud low bass (like found in Home Theatre).
A single small driver wil get into trouble quite fast. Saver to get a helper woofer that can move that air.
Thanks, I wonder if those that like large drivers, perhaps with whizzer cones, are on to something.....
How much bass boost do you consider ok to use with your fullrange speaker before you start to become concerned about distortions, intermodulation distortion probably being the most relevant?
Well, as already spelled out it depends on a number of variables, but the bottom line is how much distortion folks find acceptable and never cease to be amazed just how much many folks will tolerate if perceived as euphonic such as is common with high output impedance tube amps or later lower output impedance tube or class A amps with +20, -15 dB bass boost and certain driver designs such as curvilinear profiles that do a decent job of ~preserving its HF timing while its lower fundamentals, harmonics below our ~<250 Hz acute hearing BW is being 'stretched' over time with increasing excursion.
I use 10dB bass boost with a Linkwitz transform filter for my Tangabnd 3"ers (W3-871). These are my PC speakers, so listening position about 60cm from the speakers. They still play plenty loud with 2x 1W due to the proximity.
An it's certainly not a band aid - speaker is a totally different beast when equalized down to ~50Hz instead of the un-EQd rolloff at ~120Hz.
Well, as already spelled out it depends on a number of variables......................... certain driver designs such as curvilinear profiles that do a decent job of ~preserving its HF timing while its lower fundamentals, harmonics below our ~<250 Hz acute hearing BW is being 'stretched' over time with increasing excursion.
Yes, it certainly does depend on a number of variables, that's why I'm asking for peoples' experiences. Is the "stretching" you refer to due to Phase Modulation as described in Rod Elliott's article?
No audible problems? I tend to listen to my speakers quite close too.
Hi Jazz Man, yes I did. Managed to find two pairs that were a decent match, sanded the rounded rim flat and glued them together
Brian
Is there much difference in size? I'd get mine mail order so it would be pot luck, thankfully any step that far round the enclosure wouldn't be an audible issue, more cosmetic. They are made out of bamboo which is supposedly quite a good material for speaker cabinets?
I use a Tripath TA2024 amplifier which is fed by a 5V to 9V DC/DC converter with 2W output. The TA2024 goes into undervolt protection if I push it too hard (DC/DC converter looses voltage), so I definitely cannot go above 1W per speaker.
with 1W the W3-871 probably make an Xmax of +/- 0.5mm, maybe a tad more (cannot measure that). It should be in spec. And no, no audible distortion problems in the bass range. The speaker is not the cleanest regarding distortion but that's more audible in the critical midrange frequencies and even at levels way below max. It's certainly not a high end driver but it has given me countless nights at really enjoyable listening levels and with a lot of pleasure so far! Bass is very dry (Q is tuned to 0.5) and not earth shattering but still astonishing for such a small speaker. As you might have guessed by now, I really like these small beasts 😀
Not per se. Link? Understood, just added a couple of very common issues WRT to 'FR' systems in particular that I didn't notice in a quick scan since I currently don't have time to do much more with knowledge intensive threads, so if already discussed, never mind.
This is not totally unreasonable but why not adding sub instead? $60 sub from Amazon will not sound better?
https://www.amazon.com/Monoprice-108248-60-Watt-Powered-Subwoofer/dp/B009GUTJ34
Overall, looks like frequency modulation distortion [FMD] is the most technically correct description and seems reasonable it's the 'biggie' for wide/full range drivers in general due to doping, generally increasing stiffness as it approaches the VC junction.
