Mark Audio Alpair 11 MAOP vs. Jordan Eikona 2 - Need Help Deciding
Are there any bookshelf designs around for these or anything loosely compatible, maybe the Nostromo reflex cabinets that were posted for the 11ms?
I had a look at the tuning in WinISD, and it looks like either the small or medium Nostromo box will work fine for the MAOP 11. This is based on the standard QB3 alignment. The medium box will give you a bit deeper mid-bass, especially at around 1.0 ohm series resistance.
What amp would you be using?
jeff
E.J. Jordan and Mark Fenlon
There is a different version of this story from Ted's side. MarkAudio was a contractor and my understanding is that at no point did Ted intend to hand over the business, so the gentleman's understanding may have been miscommunication or misunderstanding. It is, in any case, water long under the bridge.
I remember reading on the E.J. Jordan site, long ago and prior to Ted's work with EAD, an explanation from Ted about ending both his professional and personal relationship with Mark Fenlon. Mark Audio was offering a new driver and called it a "Jordan" driver (I don't remember the model number, but it looked interesting to me), but according to Ted, it was a "cheap driver" designed for an "OE application," and that Mark Fenlon had not contacted Ted about the driver or its design, and Ted said he did not authorize the use of his name on the driver. Ted's statement came across as quite angry; I acknowledge that my American English and culture is different than British English, of course, but I don't think I misread Ted's anger. That direct comment and some other reports I read about Ted, suggested to me the was meticulous, deliberate, and sometimes difficult to work with; if true that would not be an unusual characteristic for a bright, perhaps brilliant, and particular sort of mind. ***I should note that in my limited email correspondence with Ted, when I suggested he has made a couple of errors in converting the US feet to meters in an article, and when I asked for clarification about a claim, he was warm, courteous, and thankful for the correction.
I have also read Mark Fenlon's comments in interviews about his relationship with Ted Jordan, and I found them to be professional, measured, and appeared to be a sincere effort to be fair. Mark essentially said that he appreciated their work together and that he learned a great deal from Ted. Mark added words to the effect that while their relationship wasn't without it's challenges, the main issue was simply that his design philosophy had evolved over time (such as his interest in developing paper cones), but Ted wasn't interested in those changes in either design philosophy or materials. Fair enough, reasonable minds can disagree.
