Looking at some horn options from 600 Hz and up
I've been looking at some horn options for 600 Hz and up.
Either using a Faital HF146 or a small wide band like the Scan-Speak 10F or Kartesian Wib70_vPA.
For the Faital HF146 I've been looking at some measurements in B&C ME90 and 18Sound XR1464C found here: [Messung] Die grosse 1,4" Messorgie - DCX464/BMS4594/NSD4015N/HF146 @ XT1464/XR1464C/PH-305/ME90/J.Sound/China - Lautsprecherforum.eu
Both of these look fine down to 600 Hz distortion wise.
ME90 gives a flatter response, and the XR1464C has better polars.
Both of these horns are about as large as I can go with regards to WAF 😀
So either I go for a flatter response or better polars..
For the wide band drivers I would probably need to go with a 2 inch exit horn.
Although I expect there would be some cancellation issues without any phase plug.
The XR1464C seems too small a horn for 600Hz. Isn't it recommended for use above 1.2kHz?
Do you want to cross over at 600Hz? That calls for a large long horn IME. Sure, some horn sellers will tell you "it's good down to 500Hz" but be skeptical, they usually aren't. The XR1464C is small, only 270mm wide and 180mm deep. I would consider that a small horn.
Here's an example of trying to build out a waveguide because it was struggling to do its job at 700Hz (that's a 15" woofer).
If those horns have some loading property at 600Hz it's of no consequence in a domestic environment and they have no ability to be useful that low.
Looking at the measurements posted in the first thread, they provide loading down to about 600 Hz before dropping like a rock. That's also where distortion starts to rise.
On the other hand I find them very important to my listening experience and the realism of the sound. Perhaps modern engineering has bent the laws of physics, but I remain skeptical of a 10 inch horn being useful down to 600hz.
But if it does work, that's great. Small and easy to use.
I'm still not sure I'd use it that low. Is that normalised? It's hard against the top, has a short scale. Is it the vertical you're showing? These plots often look artificial to me, but I'm not sure it's ARTA, just the way it's used. How about the 18" woofer for comparison?
Reactions: enzoastro
Like has been discussed in other threads recently, I don't think the idea of loading or cut-off applies to such small horns.
I think they are better characterized as waveguides.
And that their size is about how low pattern control extends, not loading.
Seems the CD being used is what mainly determines how low the CD/horn combo can be used.
fwiw, here's an outdoor on-ax meas of the bms4593 on the xr1464c taken a while back
Where do you get this confidrnce from? The xt1464 is not a small horn. Search for Dario Cinanni and his method to design horns and then come back again about loading of these items.
Confidence comes from working with the horns on some modular PA builds.
So comes from my measurements ...
here's the bms 4594he on XT1464 in magenta, on top of the the 4593/XR1464C already posted. (4594 and 4593 lower sections measured super close on whatever horn i compared)
If you have a link to something from Dario Cinanni you'd like me read, will be happy to do so. Really like the XT1464!
copying links with this damn phone... ;-)
Please search for
dario cinanni hornella
or
speakerlabs
There is a detailed article how he designed the Ciare pr614. Also a lot of math in it. With his tool several modern italian horns were created. I suspect also the xt1464 and LTH142. The absense of diffraction slots is important. He seems to optimize the volume expansion of these horns.
