Class A SE LM3886
images
A very simple way is to connect to the output and one of the rails a battery of resistors connected in parallel with a total resistance of 8 ohms. Use a reduced supply voltage so that the power dissipation does not exceed the allowable power. Resistors can be replaced with a current source, like Matsura, Pass ... Some suggest using LM317.
Nice, tho its worth mentioning i have 0 amp build knowledge/experience
On left side is input, in middle +-14v are power rails ? And on far right with little circle that are crossed are speaker output right ?
If i decide to build lm3886 in such config, will i need a preamp ? I plan on sourcing with pc connected to a fiio k5 pro DAC in lineout mode, which has 2Vrms, here are some stats.
General results FiiO K5 Pro
Channel Center/Summary
Variation in frequency response in band from 100 Hz to 10 kHz, dB -0,09, 0,02
Max voltage output at 0 dBFS, VRMS 1,98
Max voltage output at 0 dBFS, dBV 5,92
Max voltage output at 0 dBFS, dBu 8,14
Harmonic distortion at 0,0 dBFS @ 1 kHz, dB -82,5
Total harmonic distortion at 0,0 dBFS @ 1 kHz, % 0,007519
Harmonic distortion at -3,0 dBFS @ 1 kHz, dB -84,6
Total harmonic distortion at -3,0 dBFS @ 1 kHz, % 0,005869
There is a local store that have them, around 8$ each.
I also have this huge power trafo,
Prime 380v <> 2.2A
Sec 20-24-30v <> 27A
The following class A DIY amplifiers are discussed here: JLH1969, 1996, 2003, Hiraga, SE 4w, A-nirvana, Pass, followers (Macura and Chuffoli). Whether you want to repeat a finished project or start your own is your choice.
You should know that a Class A amplifier is expensive, hot and heavy. It is difficult to obtain a power of more than 10-20 watts. You need to use highly effective speakers.
I understand this.
Regarding power requirement, i would like 10-20w @8R
I have just finished my speaker project, 95db@8R, see pic's for more detail.
Currently connected on Class A SE ECC82 / 6p6s tube amp @ 3.6w, while is more than enough power for daily use, i would like something more, just in case i want it. Also bass volume is bit lacking, i would like something more punchy in terms of bass.
For example, when i first tested on my Kenwood amp class AB @50w, i managed to go to 2/3 before it got soo loud i had to abort it 😀 But i dont like how class AB sounds.
It is very neat idea. I used to do it on riaa preamps and line stage.
However, it will not be SE. Internal topology of 3886 is not changed. It will be highly biased classAB.
Is it possible to run LM3886 in class A as SE ?
Logic says no, or at best too impractical, since you start with a Class AB Push Pull amplifier, but some dauntless minds do not let facts and Logic stand in their way, so ....
This guy raises the bet: he turns a STEREO TDA**** chipamp into a MONO SINGLE ENDED amp, how´s that?
He also claims some 700W RMS out of a 2 x 15W chipamp, and feeds it from a humble 12V alarm type battery, what´s not to like?
Sheer madness, but watch it for the sheer fun of it 🙄
At least he does not endlessly babble nor use overpowering cheesy Music (except as a demo when amp works driving a "subwoofer") but you can hear Nature in the background (bird chips and the odd chicken now and then)
Warning: images include surgery and dismemberment, including leg amputations.
But no blood or guts visible, thanks God.
And yes, the amp works (sort of 🙄 )
DIY Powerful Ultra Bass Amplifier TDA7297, Simple circuit diagram
DIY Powerful Ultra Bass Amplifier TDA7297, Simple circuit diagram - YouTube
Includes (paid) demo of a nice desoldering pump
EDIT: this guy must be doing things right, just this one video (he has HUNDREDS) has 495,958 views and his Channel "Technical DIY" has 78K subscribers 😱
