Improving Wada Shigeho preamp
Hi All,
A friend of mine sent to me a board for this old preamp based on Marantz 7. As I need a pre with a veri high gain I thought to this pcb that lays in a drawer.
I thought to eliminate the NFB to improve gain (and maybe sound), but I need your advice for any other improvement.
:cheers:
Gut reaction is to mount the caps under the board, away from the tubes for longevity.
I'd probably look at a choke in the power supply too rather than just relying on an RC. Edit: I see your version has a regulator. I assume that includes the heaters?
...the power amplifier will be the MoFo
A normal power amp has gain about 20.
The Mofo is about unity.
Therefore you increase the NFB ratio about 20X to get good level matching.
I'm not sure which schematic you have, but roughly like the attached.
This also reduces the NFB from over 30dB to a mere 8dB. It will not be "dead clean" like the Marantz. But maybe that is what you want? (A $5 high-volt opamp would make dead-clean, and a lot cheaper.)
Bypassing the 1k at 2nd stage cathode would slightly increase the effective NFB. Better? Worse? Up to you.
