It's been a while since I visited, and I still know next-to-nothing about amps, and I'm hoping someone could point me in the right direction...
I need a pre-amp for a passive pick up on my ukulele, and I have next to no budget. I vaguely remember reading about some very low-cost headphone amps that were built around Altoids tins - I think it was a penguin amp.
Can anyone offer me some guidance on a very low cost, pre-built option - if any such thing exists!
Thanks a lot.
Thanks a lot.
what type of pickup? piezzo, magnetic, contact mic? knowing just what type or make and model would help to get a better recommendation for a preamp based on the the type as the impedance can vary greatly.
this may be just what you need DOD Bi-FET Preamp - Pedal on ModularGrid
Thanks @turk 182
I'm very new to playing music and amplification and I'm looking for a way of boosting the volume of my acoustic uke, in real time, "live" so to speak, and also in recordings.
I bought an inexpensive (are you noticing the theme?) clip-on contact mic pickup from Amazon.
Thanks for the recommendation - I'm based in the UK which tilts things a bit. I don't yet really understand the function pedals offer, so apologies for my basic questions. A pedal acts essentially like a pre-amp?
A while ago, while reading about another aspect of playing altogether, I read positive things about a Behringer ADI-21 pedal - would this do a similar job to the FX10 Bi-FET?
Again, sorry for the basic questions. Thanks for your help already.
Why do you need a preamp? What amp is it you want to drive with it
Did you try to connect it to your Stereo or sound-card?
@Garnett: it uses 2 AAA batteries so it is NOT passive but active.
If active it can drive about anything so noopreamp needed.
Thanks bansuri. The pick-up should arrive today so I will give that a go.Why do you need a preamp? What amp is it you want to drive with it
I had assumed I needed to run the output of the passive pickup into a prre-amp before running it into anything else.
I envisage wanting to run the signal to:-
- A portable, battery-powered speaker, just for fun
- into headphones when I'm practicing
- into my computer for some recording
- Possibly my phone also, for recording, and for Yousician (the app I'm using to learn, which "listens" to your playing and tells you whether you're getting it right or wrong)
Hmmmm. I may have made an error here. I can see that just as you say, the product page states it requires batteries, but I completely missed that, and was going off the pictures and assumed it was a passive pickup (which is what I wanted).@Garnett: it uses 2 AAA batteries so it is NOT passive but active.
If active it can drive about anything so no preamp needed.
I'm unsure now - all the pictures suggest to me that it is a passive pick-up and I think the reference to batteries is an error.
Thanks for your reply! I need to read more carefully. I shall let you know what arrives!
no it's likely an electret element which requires a voltage source to operate but with no listed impedance saying it will drive just about anything is a little misleading, once it arrives trying it with all the widgets you intend to use will determine if a pre-amp is needed.
the Behringer ADI-21 pedal may well have enough gain for your needs and as it provides more tonal variation it may prove better...if you can see if a local music store or fellow local musicians have the units and would be willing to let you try them before you make a purchase.
try before you buy is not possible with online retailers....
Hello. I'm guessing here but does it magnify the sound when you use a pick up with the uke? I don't see a plug in to go directly to the amp so one would need a pick up, right? Or do I have it all wrong? Do they really make a big difference on an acoustic uke using a pickup vs not having one? What would be a good/decent inexpensive pickup to use assuming the above is correct? Thanks.Thanks @turk 182
A while ago, while reading about another aspect of playing altogether online baritone ukulele tuner, I read positive things about a Behringer ADI-21 pedal - would this do a similar job to the FX10 Bi-FET?
Garnett never got back to report his experience with what he ordered.
there's lots to pick from when you google ukulele pickups and very inexpensive ones at that, i have no recommendations to make as i have not tried them personally. a local musician i know has an LR Baggs system on his uke that he swears by.
wow! You would expect loads of schematics for such a simple question.
My mind says bf 244, I don't know...
https://isoondaomradio.weebly.com/preamplificatore-audio-a-fet.html
- Live Sound
- Instruments and Amps
- Any (very) inexpensive pre-amps I could use for a ukulele?
