images
Attach your image in the normal way and then click the symbol here which will list all the attached images.
You can then click each link and the required link text will drop into your post which will display as the image when you post. You can copy and move the links around your post as desired.
All this will change when we move platform and the image hosting of XenForo should be much smarter.
Clicking on those images takes me to a new page where only the picture is viewed which is not particularly user friendly.
How come some pictures are able to be panned in and out, while others are not, and how do one attach a picture so the picture do become pan-able?
This is the HTML code for one of the pictures in post #2:
<img class="tcattdimgresizer" src="https://www.diyaudio.com/forums/attachments/forum-problems/782534d1569052108t-images-aleks-png" alt="images-aleks-png" style="margin: 2px" title="images-aleks-png" border="0">
which differs from an attached picture which is pan-able as seen in another post, the main differences are emboldened and underlined.
<img class="tcattdimgresizer" src="https://www.diyaudio.com/forums/attachments/multi-way/779763d1567787887-birth-15-inch-woofer-spider-assembly-png" alt="The birth of a 15 inch woofer-spider-assembly-png" title="Click the image to open in full size." width="600" border="0">
Anyhow, hope the change to XenForo BBS rectifies the problem with attached pictures.
So 🙂 after 30 minutes playing around and looking at your example...
The image is attached in the normal way. You then copy the bit I've highlighted and post that where you want the image.
You then put 'Image' tags around the links... whcih doesn't seem to work using the button... so add them manually.
attachment.php
attachment.php
attachment.php
attachment.php
