How to power lm386 up with wall adapters ?
pasteboard is not a good place to host images. Re-size appropriately and host here. See below.
What happens when you try? Smoke? Buzz? Do you have a voltmeter? Does the voltage read right both no-load and full-load? Is the polarity correct? What happened where the shrink-wrap is near the RFI-lump?
There are a couple possibilities:
1. Adapter has no filter cap? ( be sure your amp has a large cap across the power supply)
2. Grounding problems. Two-pin switch-mode adapters have a problem with grounding that places half the AC mains voltage on the output because there is no safety ground connection to connect the AC input filter to. Connecting your amp ground to earth ground will short this voltage the way a 3rd pin would. Linear transformer adapters generally don't have this problem because they have no switching noise filter on the mains input. For this reason, any switch-mode power supply requires an earth ground.
Post a picture of your actual build.
Maybe/probably there is some grounding/decoupling problem which is easier seen than described.
The old "one image is worth 1000 words" 😉
Batteries are less critical in that aspect, they don´t hum, buzz, ripple, hiss, etc. but switching supplies often let some switching noise/hash through, let´s see what you have.
Well connected, it MUST work, and 1A is more than enough.
Here is my circuit
Use a linear supply, with extra pF capacitors.
Or rechargeable cells (those from old cell phones last years).
You do have to charge them, put 2 * 3.7V in series, use a 9V adapter as charger.
I'm also planning to use a 18650 li-ion battery hooked into a continously charged charging module if i will not be able to find a way to supply the circuit.
You do need a bypass on pin 7! Yes, sometimes it works without, but not as designed, and is super-susceptible to power rail feedback.
You really need a capacitor from +9V to GND, very close to the chip. A power rail bypass.
A battery on short leads is sufficient bypass for some '386. A long wire with an RFI filter from a wall supply is not good bypassing.
bypassing
Thanks for your reply, how can i bypass lm386 ? When i try to add an electrolytic capacitor between 9V and GND, it warms up after a while.
After taking a look at adapter, i saw that there is a cylindrical part connected to adapter's cable in series. It may cause distortion in circuit but i don't know.
Try 100uF x 16V or 25V
Electrolytics have polarity, maybe you plugged it in upside down.
Same with the one feeding the speaker which by the way I can NOT find in your pictures 😱
Are you feeding DC into your speaker? :sour:
sorry for late reply
I assembled the components to perfboard, i solved half of the problem with using a 7805 voltage regulator. But after a detailed research, i think i found the main problem. Ground looping. I tested the circuit in different rooms, different ac sockets. And i noticed that when i tested in living room there is no more noise except lm386's own noise(there weren't any devices plugged into sockets ). I'm gonna use this circuit when i'm using computer. So i don't want to listen noise instead of music. What should i do ?
