What is the Universe expanding into..
Do you think there was anything before the big bang?
  • I don't think there was anything before the Big Bang
    Votes: 56 12.5%
  • I think something existed before the Big Bang
    Votes: 200 44.7%
  • I don't think the big bang happened
    Votes: 54 12.1%
  • I think the universe is part of a mutiverse
    Votes: 201 45.0%
  • Total voters
    447
A thought just occurred to me. How is there expansion in space when there's no heat to allow movement?
of space itself
The expansion of space is conceptually different from other kinds of expansions and explosions that are seen in nature, and does not involve heat.
Without the objects themselves moving, space is somehow 'growing' in between them.
It is the metric which defines distance that is changing rather than objects moving in space. (The metric is a formula which converts coordinates of two points into distances).
Unlike the metric of space, the metric of space-time is non-Euclidean i.e. not just three dimensions and three coordinates, but four, to include time.
The non-Euclidean nature of space-time manifests itself by the fact that the distance between points with constant coordinates grows with time, rather than remaining constant.
In other words, in expanding space, distance is a dynamical quantity which changes with time.
Now, colour me smug! 😀
How are they constant when they are not? Has this ever been verified with measurements?
Also, how is there a time delay for light "reaching" us when nothing can move faster? How did we get to our coordinates faster than the light from objects further back in time? Why have they not been observable the whole time since the big bang?
That's five questions in a row, Pete! Be easy on me!
In answer to the first question, the coordinates remain constant, but the metric that calculates the distance between any two points is changing.
Now that's where the boffin mathematics come in, which neither you nor I are unlikely to ever understand!
Jupiter's rings and moons exist within an intense radiation belt of electrons and ions trapped in the planet's magnetic field. These particles and fields comprise the jovian magnetosphere, or magnetic environment, which extends three to seven million kilometers toward the Sun, and stretches in a windsock shape at least as far as Saturn's orbit -- a distance of 750 million kilometers (460 million miles).
As the magnetosphere rotates with Jupiter, it sweeps past Io and strips away about 1,000 kilograms (one ton) of material per second. The material forms a torus, a doughnut-shaped cloud of ions that glow in the ultraviolet. Some of the torus's heavy ions migrate outward, and their pressure inflates the Jovian magnetosphere, while the more energetic sulfur and oxygen ions fall along the magnetic field into the planet's atmosphere, resulting in auroras.
Io acts as an electrical generator as it moves through Jupiter's magnetic field, developing 400,000 volts across its diameter and generating an electric current of 3 million amperes that flows along the magnetic field to the planet's ionosphere.
Voyager - Fact Sheet
400 000V and 3000 000A huh?! So that's about enough to power a big-ish laser to restructure the entire solar system, melting one asteroid at a time.
Build it on Io and just aim it where you want stuff to happen.
We know they are moving apart because of redshift. The one thing that is constant is the speed of light c. So if c is constant everywhere in the universe, but it redshifts more and more the further back (= further away) no matter what the direction we look, we can deduce that any two points (or any number separated by some distance) are moving apart.
As Galu explained way back, local gravitational action may act as a countervailing force - as for example between the Milky Way and Andromeda which are moving towards each other.
Are you saying an object will always appear to be located in exactly the same position even though expansion has changed it?
As I've said, the objects do not move - the distance between them simply gets bigger.
This concept trancends our everyday experience, and may only be apprecated from a mathematical standpoint.
Our understanding of space-time requires that what we see normally as 'space', 'time', and 'distance' are not absolutes, but are determined by a metric that can change.
The metric expansion of space is a feature of many solutions to the Einstein field equations of general relativity, the simplest of which allows for the distances in space to change with an evolving scale factor.
In an expanding space-time, the metric changes with time in a way that causes distances to appear larger at later times. This explains why galaxies that are more distant from us appear to be receding faster than galaxies that are closer to us (Hubble's Law).
The Juno mission, in conjunction with the Hisaki satellite and Keck observatory, has recently discovered that Jupiter's intense aurora is responsible for heating the entire planet’s upper atmosphere to surprisingly high temperatures.
Juno Joins Observatories to Solve "Energy Crisis" on Jupiter
Sitting more than five times the distance from the Sun as Earth, Jupiter is not expected to be particularly warm. Based on the amount of sunlight received, the average temperature in the planet’s upper atmosphere should be about minus 100 degrees Fahrenheit or a chilly minus 73 Celsius. Instead, the measured value soars to around 800 degrees Fahrenheit or 426 Celsius.
And why would evolution (life as we know it) move in the opposite direction to that of entropy?
It only does that locally. 'The System' is the universe, and on that scale we still move toward entropy. But you can beat entropy locally and for a limited time without violating the big picture. We see it with life, we also see it for, like, solar systems. The order is limited in place and time (spacetime?).
Jan
Here is an article by Adam Reiss on the accelerating expansion of the universe...
What I gather from the article is that very distant supernovae have revealed a point in time when the expansion of the universe changed from slowing down to speeding up.
This is significant as it suggests that the expansion of the universe has not always been speeding up and bolsters the argument for the existence of dark matter and dark energy.
Whether or not the expansion is slowing down or speeding up depends on a battle between the gravitational pull of matter (most of which is dark matter) and the gravitational push of dark energy. What counts in this battle is the relative density of each.
It is presently thought that the density of dark energy does not to change as the universe expands. Conversely, the density of matter is decreasing as the universe expands.
Currently the density of dark energy is higher than that of matter, but in the distant past the density of matter should have been greater, so the expansion should have been slowing down then.
We know very little about dark energy, and the future of the universe hangs in the balance should the density of dark energy prove to change with time.
Yes - looks like the crossover point was the 7-9 billion yrs ago that I mentioned earlier.
The next few yrs in cosmology are going to be interesting that’s for sure.
Einstein’s Lambda afaik did not predict an acceleration of the expansion of the universe, so indeed something mysterious is out there!
