DATS V3 in a Virtual Machine on OSX
Has anyone had any luck with DATS in a VM? I keep running into an issue where the output signal has tons of static. Some research leads me to believe it is an issue with IRQ buffer sizes being 1 instead of 10 on older windows, but I also see plenty of people discussing this in the context of it being virtual box as the issue.
I have a few systems at my disposal, but the M1 mac cannot run x86 vms at all, the 2015 MBP with only 2 cores but 16gb ram is mostly up to the task except for the static filled sound, which is only from the DATS - from youtube through the laptop speakers via that driver path is fine. I started on the M1 as it is my current personal machine, then moved to the 2015 machine, so my next step is either a 4 core 16gb i7 linux laptop with virtualbox ( change host from OSX to ubuntu in hope that fixes it) or my work machine which is also OSX but has more resources 2->6 cores, 16gb ->32gb ram ( would rather not mix stuff onto work machine) I suspect more resources is not the answer. I fear a different host is also not the answer, but in the hopes someone has a working VM setup without running windows as a primary OS as I have managed to avoid that for 17 or so years now.
I use usb passthrough in vmware player on ubuntu -> win10 guest. USB enumeration works reliably, but larger loads with USB2 and data packets every 125us get samples dropped every few secs - probably the SW overhead is too big for the fast communication.
I ran my DATS v3 on a 2017 MBP (fully spec’d) in VM using Fusion without issue. But I actually prefer running the DATS V3 natively in OS X using REW (Room EQ Wizard) because I like the REW interface, calculation method, plotting and data export flexibility. I’ve been meaning to do a write up showing how to do it. I’ll try post something soon.
Thirded! 🙂
I run DATS v3 via a Windows 10 guest in Virtualbox 6.1 on a Macbook Pro host but get stuttering every 50-100 ms, regardless of the VM configuration - and I've played with it quite a bit. I'm tired of what that does to my measurements, so any future hours spent researching seem better applied to exploring the configuration of REW on my Mac to use the DATS hardware. A quick check shows that John has expanded the calibration options since last I looked, but I need to dig into it more to see if it now aligns with what DATS expects, as well as assess proper level settings, as my quick first attempt came back with levels too low. (Though I really did want the VM option to work to avoid losing the rub/buzz test of the DATS sofware.)
IIRC there's a single thread on all the USBs causing starvation and the latency is unpredictable. I can't remember what I was doing at the time but I remember researching it and those two points came up. That was on OSX, VirtualBox and Windows for telescope control.
