Opinions on Mods to FF85wk
Would I be better off leaving them stock
IME, yes, since preserving as much efficiency as practical is the ideal goal and based solely on the published response plot, toe them in 15-30 degs or more so that they cross at some point in front of your face [usually about the width of it] where they sound most tonally balanced over the widest BW and if the extreme HF is missing, then either boost 16 kHz-up or add a true super tweeter [typically a piezo element] capped off ~ [4 - 6] octaves higher to 'taste'.
This is the kind of paint you want.
Testors Enamel Paint 1107 Turquoise
Google is not finding me Japanese sources. You are looking for a hobby shop that sells plastic models.
Gloss: Model Master Acryl Clear Flat, 1 oz.
This should be at the same model store.
ModPodge should be findable at a general craft store. Also the ZIG, but finding the exact brand could be tricky. It “dries” if left inthe air, put it between 2 pieces of paper and it is like stickies.
Here is a set of A1/A2/A3/A4/A5 nibs: Speedball Calligraphy Nibs | The Paint Spot - Art Supplies and Art Classes, Edmonton
And a 56: https://www.amazon.com/Speedball-School-Pen-Fine-Pack/dp/B000BYT4DY
dave
Wow FF85wk is amazing driver.
So smooth than I thought from reviews in my environment.
Feel like why I didn't have this until now???
I also bought solid core cable made by Audio-technica.
Solid core cable is best for me.
Thank you Dave,uFonken box plan is the art.
