The specs that i found was
Sensitivity (dB): 94
Frequency Response (Hz): 40Hz - 5200Hz
Resonance Frequency (Hz): 46
Thielle Small Parameters:
BI: 12.73
Qms: 8,900
Qts: 0.510
Sd: 0.051m2
Vases: 87,7L
Vd: 255cm3
Xmax: 5
Maybe can use 2 of them, want to use it for HT with linearray as main speakers.
I can get 2 JBL for half the price of Faital Pro 12fh510 or Faital Pro 12FH500
BI: 12.73
Qms: 8,900
Qts: 0.510
Sd: 0.051m2
Vases: 87,7L
Vd: 255cm3
Xmax: 5
What do you expect from a HT sub? What range or SPL are you aiming for?
Personally, for a HT I would like a bottom of at least 20 Hz. Will be hard to reach that with Fs = 46 Hz.
I dont care about SPL, mainly want to go lower, 20hz will be great.
Dont know if can get some driver in Argentina that let me go 20hz low without sell my house to purchase it
Options that i found are Alpine S w12d4 and B52 Flm-812 can run at 8ohms but looks like are mainly for car audio
I'm from Europe. Not familiar with Argentinian market.
But I think Parts Express, one of the biggest in DYI audio, has international shipping: Shipping Policy
Impossible to purchase from Outside Argentina, needs to find something local
Other two brands that i found in argentina.
Faital Pro (Italian, good price, good drivers)
American Vox (chinese, cheapest, but looks OK these TS parameters)
Altavoz American Vox – AV1506 – American Vox
Altavoz American Vox – AV1806 – American Vox
Altavoz American Vox – AV1844 – American Vox
Faital will be the best then, but to get low you will have to use 18" drivers i think to get low and you will not reach 20Hz. To do that you need special drivers that are build to go that low. Those chinese look suspicious to me and don't have the right specs neighter to go that low.
I have looked around for some big wooferbrands delivering in Argentina. Found this one. I know Eminence has some awesome drivers like the LAB12.
International Eminence Speaker Distributors | Eminence Speaker
Hope it helps.
Hope it helps.
Thanks for search! Looks like the website dont work, will call tomorrow to see if they still selling that brand.
Thanks!
Thanks!
As a general rule, not a good plan to tune a driver below Fs > a half octave, so for 20 Hz tuning = 20 * ~1.4142 = < ~28 Hz Fs.
The problem with getting gear outside of Argentina is the import taxes...Buy a $155 driver from, say Parts-express, maybe $75 to ship it here.
When said goods arrive, the post office will search for a legitimate receipt & charge you the $155 just to get it into your hands...155+155+75=385 ...yikes huh?
Now Argentina makes its own gear, I'm running right now a vintage 12" full-range in upgraded original cabinets...Leea is the brand & they seemingly make lots of raw drivers along with the T/S parameters to engineer your own.
------------------------------------------------------------------------Rick....
Link? Every one I've found are either vintage info or dead and a 2008 forum post says it's long gone.................
Tienda online de Xpro en Argentina | XproStore | Argentina is the actual site i think for the emminence dealer in AR. But i don't see the Lab drivers in their range (that is very limited)
At least they got the Delta Pro18A.
If you have some space and SPL is not an issue, you can get around 110 dB at 20 Hz on 80 Watts, limited by cone excursion of 6,7 mm.
In fact you can load it to Xlim of 15 mm at 400 W, but you need a bigger vent to handle that.
Thanks i dotn have problem with size, so can build the box using 600l
And price looks good in argentina too, just 250USD, similar to USA.
FWIW, Keele's Extended Bass Shelf [EBS] alignment = ~1282 L tuned to ~14.6 Hz, though recommend 16 Hz tuning and you'll ideally need a 5.4 ohm series resistance or some form of frequency shaping EQ to flatten its response, though tuned this low, room/boundary gain may do it good enough.
Power handling of course is quite low at 20 W/16 Hz/~108 dB m/2pi, so better to have it hard against a wall for ~114 dB/1pi or corner ~120 dB/0.5pi, all assuming a massive/rigid construction of course.
An 8"/20.32 cm dia. vent x 5.75"/14.6 cm yields a very efficient ~11 m/s vent mach.
- Subwoofers
- This driver JBL 12" 12PW will work as subwoofer for a HT?
