D
Deleted member 148505
Then I also have the wrong BOM...
You sent me the boards you show on your Ebay listing, without the SMD pads for D3 and D4, but through holes. That is why I was asking about DZ6.2BGWX.
I was surprised these were sent when you were listing V3. Guess I got V2 boards, but you emailed me everything for V3.
For the cost of everything involved, should I bail on these boards and get the V3's?
Hi Dave,
Thanks for helping us with the shipping fee. We will send 2 boards this week.
Lester
Given the choice of 2 Meanwell HLG smps would you choose 48v 3.9A (180w) or 36v 8.9A (320w).? For Sylph-D200 or 260btl
D
Not sure if LED driver supply is suitable for amplifiers.
You can use LRS-350-48 adjusted to 45V. I have a LRS-350-36 here and the RTA measurements are very clean (can be adjusted to 42V), no mains harmonics (as clean as my connex SMPS used in my ASR build). Get it from reputable stores like mouser / digikey so that you'll get a genuine unit.
Lester
Thanks Lester. Why not on the HLG? I assumed a lot of the MW range were for leds. What is it about the HLG that isn't suitable..?
Just my inquiring mind. I probably won't understand the answer!
I have the aforementioned psus in my ebay watch list from. A reputable supplier but if they're not good enough I shall pass them up.
D
General purpose Mean well SMPS like LRS series has a constant voltage output. It will have a stiff voltage output provided that you won't exceed its current rating.Thanks Lester. Why not on the HLG? I assumed a lot of the MW range were for leds. What is it about the HLG that isn't suitable..?
For LED drivers they have constant voltage and constant current modes.
You must be careful when selecting a LED drivers to power an amplifier, for example if you get HLG type AB, it will have a constant current output, so its output voltage will fluctuate depending on load current applied.
Lester
D
soundcard interface prototype development
I'm currently improving my JLE interface (similar functionality to pete millet's interface but without the RMS voltmeter)
My interface prototype uses INA1651 and OPA1656 and I'm currently using it to measure my Sylph-D200.
First pic Motu M4 loopback (SE)
Second pic Motu M4 + JLE Interface loopback (SE).
Slight loss on the output signal (due to input impedance). Only slight degradation on THD+N!
Problem is that the results are good because the input and output diode protections are removed, If I put them back, the loopback THD+N will become worse (+6dB). So I'm currently looking for input and output protection methods.
Motu M4 uses TPD2E007 for each terminals, i will look for similar methods.
I buy this when you get it working.
Did I send the wrong number of parts - apologies, my bad.
I'll PM you with stretchneck's address - thanks for taking care of it.
Received one of the slow ramp board - can you send me the remaining 4 please?
I sent the four boards a couple of weeks ago, Jim just sent the additional one because I didn't count correctly. You should have had a PM from me?
A stupid question.
Is it possible to make an TPa3255 only for HF?
To skip the LF and gain something?
D
A stupid question.
Can't understand the question. You can use active crossover to use TPA3255 in HF.
Lester
D
My SKA GB150D
Test fitting my SKA GB150D on a small BZ2107 chassis
Bum - the others never arrived then...
Lester
I use active crossover and what I wonder is to with caps on input limit it to
2khz and up or is
it just stupid?
Lester
2khz and up or is it just stupid?
Maybe an another inductor for HF?
We are many that run active.
D
Advantage is that you can select a lower value input coupling cap, you will still be needing the active crossover to do the work since it has steep filters.
D
The Diotec BC546B, 546C, 556B and 556C transistors I ordered from Poland showed up today.
All I need are the SKA GB150D boards now... 🙂
Nice, shipping may take up to 6 weeks to Canada.
- Vendor's Bazaar
- Amplifier Modules and PCBs For Sale
