Miro's DAC is a brilliant implementation of the AD1862 non-oversampling R-2R DAC chip, which not only sounds great but lends itself to all sorts of experimentation.
You can read more about the DAC here.
The Auction
I'm auctioning two completed DAC boards to raise funds for DIYaudio's preferred charities: Donations to two great charities – diyAudio Store .
Both causes are great and you're free to choose, but perhaps consider the increase in suicide/suicide attempts during COVID.
Because you'll pay by showing me the receipt from your donation, 100.0% of funds will go to the charity.
I'll mail the DACs to the winners anywhere in the world* at my cost. Insurance and any import duties are on you.
* Where served by the US and your country's postal service.
The DACs
Both DACs were built and tested by me, using Kester SN63 solder and good components including brand 2 new AD1862N from Rochester Electronics. Panasonic FR, Nichicon, Wima MKP caps on the digital side and Wima MKS on the audio side. I/V resistors are 1.5k ohm General Resistance (Rhopoint) 8G16D and are socketed if you decide you want something even more esoteric.
They both sound good but each is packaged a little differently.
The Experimenter DAC has sockets for DIP op amps and the audio-side electrolytic caps, allowing you to test and tune. Panasonic FR caps and 4898, 4627 and 828 op amps are included to get you started.
The Listener DAC has LM6171 SOIC op amps and Elma Silmic II audio-side electrolytics soldered to the board and is ready to make your ears happy.
Remember that the auction is for the DAC boards only, before you can listen you'll need to provide an i2s converter for whatever data source you're using and good quality +/-5VDC and +/-12VDC power supplies.
The Rules:
You don't have to be a diyaudio member to bid, but maybe you should join, eh?
The Auction is what we here in Virginia farm country call "by the each." Bid a price per board, and the winning bidder can buy one or both at the winning bid price (x2 if taking both boards). If the winner only takes one board, I give the next-highest bidder a chance to buy the other board at their bid price, going down the list if that bidder declines.
Bidding is easy - reply to this thread with your bid, keep watching to see if you get outbid, then bid higher.
Bidding is open now and ends at 1600 UTC/GMT on Saturday 26 June 2021. The official countdown timer is here
The winning bidder must donate within 24 hours, else I'll go to the next bidder.
Good luck and please be generous!
The Auction
The DACs
The Rules:
Looking good so far!
Remember, this is a by-the-each auction, so you're not bidding on a specific board. At the end I'll be going down a single list of bidders from high bid to low, offering one or both DACs to the top bidder, then on to the next bidder if the high bidder doesn't want both.
Nice gesture Myint, one suggestion better to mask your mail ID and the Card details for security reasons 🙂
Thanks, Myint! I'll have the DAC out to you no later than Saturday.
You can delete the receipt 🙂
DAC received safe and sound! Thanks and will report back once i have it fired up. I'll be able to compare it to my Subbu which i expect it to soundly beat, and a couple commercial DACs by Abbas Audio.
Excellent news! It will play well out of the box, but will benefit from tuning.
My son and I did some testing of resistors and capacitors in the audio path, and I would suggest you do the same. You'll probably hear a substantial difference with good audio electrolytics such as Silmic or Nichicon FG in C27/28 and C32/33 versus the Panasonic FRs in there now. Then try replacing R8/R9 with a standard resistor and you can decide if USD20 resistors are a silly idea or not. I was surprised.
I think I would have spent less on op amps if I'd focused on the passive components first 🙂
How did it compare in relation no the abbas DACs?DAC received safe and sound! Thanks and will report back once i have it fired up. I'll be able to compare it to my Subbu which i expect it to soundly beat, and a couple commercial DACs by Abbas Audio.
I've only managed to listen briefly, it sounded great but it's still waiting for proper PSU and time to box it up.How did it compare in relation no the abbas DACs?
