Having thought about this I would guess that the HV (main accelerator voltage) is low. That will cause the defection to increase and typically the increase is larger at the edges than the center. A failing HV rectifier or some crud could be causing a lot of leakage.
Cool ohm, Can you take a photo of the CRT plug and the thin rotator discs glued near the CRT plug? I'm thinking magnetic alignment or linearity gain on the horizontal ccts( 1 div OK, 4 div bending) .
Check for CRT shield near the front panel & no loose wires leading to the CRT.
Watch out of high Voltage.
Cool Ohm, Try this method. With the same 4 div waveform on the screen, move the Horz position knob left or right and see if the good sine waveform bends in real time towards the edge.
Good thinking. I wonder if altering the brightness up and down shows a change in the problem. Low EHT makes the beam easier to deflect and so if the brightness is whizzed up and down and the image size on screen alters then that points to a problem.
Using the squarewave Cal signal was one reason I wanted to see if the sweep was basically linear and that the markers line up OK. Do they ?
Also thinking aloud and just covering all bases.
Are those two large speaker cabinets I see in the picture? Big unshielded magnets? but then it wouldn't still be OK at low amplitude.
Any change if you turn the scope on its side?
Sometimes there's just a pot to adjust pincushion/barrel distortion... First establish if that is the case I think.
Dried alcaps probably? As a version: the vertical deflection makes some ripples on the rail shared with horizontal one.
That is why I suggested the use of another oscilloscope to aid in troubleshooting this one. Trial and error is no way to repair anything.
-Chris
-Chris
- Design & Build
- Equipment & Tools
- Oscilloscope distorted waveform at edges
