78rpm RIAA curve
AFAIK, the nearest thing to a 'standard' on 78s (which were not all 78rpm) was the Western Electric cutting head and/or the copycats made to evade WE royalties. This is semi-documented in the RCA papers printed in AUDIO. The WE cutter was not reference-grade because the damper(s) drifted out of tune and were not cheap to re-rubber.
Here's a different analogy. WWJD? Joseph, the carpenter who raised the Christ child. Look for his joist and rafter span-table. How big a log to span 7 cubits? We don't know exactly what he would do. There was no Building Code. There was hardly the math to compute loads (just as the speakers in 78 shops were not real good). Moreover, while post-1957 cutters could be quite flat and all EQ first-order, older cutters could have complex resonances and non-minimum phase delays. IMHO most 78s can be EQed the way they did in the old days: by ear, with allowances.
