Replacement for vintage Sprague axial capacitor
Hi, I need some help. I have done some research but still can't find enough information about this Sprague 25uF 0-25VDC axial capacitor.
It looks like it needs to be replaced. Any suggestion is most welcome.
Its in an amplifier I bought 30 years ago. I suspect the cap is even older. It looks like the red cap/seal is breaking or melting and since I already have it opened up, I just might do some work to make it last longer. It is running alright.
If you can, check for leakage with resistance range in 10k or so with a meter.
Also, if you have one, check its capacitance with a meter.
Could be age related break down of the casing.
Sprague are good, I don't know what kind of capacitor this is.
You looked for a replacement in axial construction?
What is its function in the circuit?
Thank you Naresh. This is in a power supply board. Not sure what's its function though. I have a regular meter and can check the capacitance but don't have a ESR meter. I know Sprague is good so I want to get a good replacement. For peace of mind.
Thank you for all the suggestions. I initially just wanted to restore the amp in an authentic way. Vishay is still producing the Sprague axial caps, but their price and specs are kind of disappointing. Illinois also has some axial caps. Priced even higher.
Would the Sprague (bigger size) last longer than the radial caps?
What is the amp make?
Track side soldered components with through holes...late 80s or up to 1995 or so.
No heat sink for the power transistor.
It has worked well, and in most cases would be considered end of life.
If it is still working well, a nice well designed and well made unit, with generous component ratings.
Treasure it.
